Lattice Holoscan Sensor Bridge - LI IMX715 Camera
Hi Team
We are using this camera LI-IMX715-MIPI-D-HOLOSCAN-080H from Leopard Imaging.
Platform - Jetson AGX Orin - Jetpack 6.2.1
HSB - Lattice HSB board with latest firmware flashed
Holoscan SDK - 2.3.1
We followed this https://docs.nvidia.com/holoscan/sensor-bridge/latest/index.html and everything set perfectly. Running this example “$ python3 examples/linux_imx715_player.py“ gives following i2c error.
 File "/usr/local/lib/python3.12/dist-packages/hololink/sensors/imx715/imx715.py", line 174, in configure
    self.configure_camera(imx715_mode)
  File "/usr/local/lib/python3.12/dist-packages/hololink/sensors/imx715/imx715.py", line 506, in configure_camera
    self.set_lane_cfg(0x0004) # Mipi lane: 4
  File "/usr/local/lib/python3.12/dist-packages/hololink/sensors/imx715/imx715.py", line 388, in set_lane_cfg
    self.set_cmd(CMD_ID_LANE_CONFIG, 0x0002)
  File "/usr/local/lib/python3.12/dist-packages/hololink/sensors/imx715/imx715.py", line 240, in set_cmd
    self._i2c.i2c_transaction(
RuntimeError: I2C port indicates I2C_I2C_NAK
Please give us your inputs which might helpful to resolve this.
hello ahamedmuqthar,
since it’s the error regrading to i2c communication.
did you verified this sensor driver on AGX Orin via CSI connector?
hello JerryChang
I connected this camera directly to the MIPI connector on the AGX Orin. However, when I run v4l2-ctl --list-devices, no video devices are detected, and nvgstcapture-1.0 only opens a blank window.
Could you please help me determine if this might be a driver-related issue?
I appreciate your help.
this should be driver bring-up issue.
you may running Jetson-IO to configure CSI connector. for instance, $ sudo python /opt/nvidia/jetson-io/jetson-io.py as you can see.. it’s not support IMX715 by default.
you must apply kernel update to enable IMX715, please contact with sensor vendor for the support drivers.
