When doing a make on on a cloned repo, all of the .so files copied from an x86 server were being flagged as “skipping incompatible” resulting in a failed make. I compared the ldd output of the same .so files in the x86 server to the Jetson. On the x86 server the ldd output looks normal, on the Jetson I get “not a dynamic excutable”. File size remained the same after the scp-ing over to the Jetson. Any idea why this happens? Thanks in advance.
x86 server:
$ldd libbgr2lab.so
linux-vdso.so.1 => (0x00007ffc78fee000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe360c12000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe360909000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe3606f3000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe360328000)
/lib64/ld-linux-x86-64.so.2 (0x00005609572ef000)
Jetson tx2:
$ldd libbgr2lab.so
not a dynamic executable
What does “file libbgr2lab.so” show? Probably one of the biggest problems would be if part of the x86_64 environment was linked in. I’ve also seen files indirectly downloaded over wget actually be the HTML web page…but named with “.so”. It’s hard to say from the above.
nvidia@tegra-ubuntu:~$ file libbgr2lab.so
libbgr2lab.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, not stripped
nvidia@tegra-ubuntu:~$ objdump -i libbgr2lab.so
BFD header file version (GNU Binutils for Ubuntu) 2.26.1
elf64-littleaarch64
(header little endian, data little endian)
aarch64
elf64-bigaarch64
(header big endian, data big endian)
aarch64
elf32-littleaarch64
aarch64
elf32-bigaarch64
aarch64
elf32-littlearm
arm
elf32-bigarm
arm
elf64-little
plugin
arm
aarch64
elf64-big
plugin
arm
aarch64
elf32-little
plugin
arm
aarch64
elf32-big
plugin
arm
aarch64
plugin
srec
(header endianness unknown, data endianness unknown)
plugin
arm
aarch64
symbolsrec
plugin
arm
aarch64
verilog
plugin
arm
aarch64
tekhex
plugin
arm
aarch64
binary
plugin
arm
aarch64
ihex
plugin
arm
aarch64
elf64-littleaarch64 elf64-bigaarch64 elf32-littleaarch64
plugin ------------------- ---------------- -------------------
arm ------------------- ---------------- -------------------
aarch64 elf64-littleaarch64 elf64-bigaarch64 elf32-littleaarch64
elf32-bigaarch64 elf32-littlearm elf32-bigarm elf64-little
plugin ---------------- --------------- ------------ elf64-little
arm ---------------- elf32-littlearm elf32-bigarm elf64-little
aarch64 elf32-bigaarch64 --------------- ------------ elf64-little
elf64-big elf32-little elf32-big plugin srec symbolsrec verilog
plugin elf64-big elf32-little elf32-big ------ srec symbolsrec verilog
arm elf64-big elf32-little elf32-big ------ srec symbolsrec verilog
aarch64 elf64-big elf32-little elf32-big ------ srec symbolsrec verilog
tekhex binary ihex
plugin tekhex binary ihex
arm tekhex binary ihex
aarch64 tekhex binary ihex
Here’s the problem (excerpt from the “file” command):
x86-64
…this is for a desktop PC, not arm64/aarch64. It needs to be created with the cross-architecture tools if building from a PC…and anything linked against needs to be arm64/aarch64. A Jetson won’t recognize this…x86-64 is a foreign architecture when a Jetson sees it, arm64 is a foreign architecture when a PC sees it. I’m not sure what all of the other output is, but “file” should not have seen x86-64.
Thanks! We inherited this repo with the .so files already packaged. Would you happen to know of any sources for these libs compiled for arm64/aarch64?
libbgr2lab.so
libattribute_analysis.so
libsecurec.so
I didn’t see any of those from apt search. If they are available in source form you may be in luck. One thought on this though is that “libsecurec.s” sounds like a security modified libc…if this is the case it probably has x86_64 assembler or other architecture-dependent code in it…in which case not only would the source code be required, porting to this architecture would also be required (not everything in x86_64 applies in arm64, especially security issues).
