Hi All,
Actually i am creating a Person detection application in Jetson TK1 and running it on different Jetson boards.But from so many days i am facing a problem on my Jetson TK1. I am totally blank whats going on with the system. I am just a novice with Jetson TK1.
First I took a Jetson TK1 for now name it as “J1” on which i installed CUDA, opencv, cudnn, caffe etc. using Jetpack 2.2.0.Here the L4T was 4.0, I wrote a code using Caffe which detects human and light up the LED when a human is detected. I build the project, compilation was successful and the executable got created , and it got executed pretty well.
Then what i did I took another Jetson TK1 suppose “J2” use the same Jetpack version and installed everything. Version of L4T was 4.0 .Then I used the same binaries of “J1” and gave a run on J2. It didn’t work and thrown this error ::
ZN5caffe3NetIfECIERKSsNs_5PhaseEiPKst6vectorISsSaIsEEPKs1
i reflashed the J2 and again gave a run it worked.
Then i used Jetpack version 2.2.1 downloaded and installed all the pee-requisites. Here the L4T was 5.0. I build the binaries in J1 and ran the binaries on J3 with L4T version 5.0. It worked. Then i used the same binaries and ran it on the J2(L4T 4.0) it worked. after couple of days i again ran the binaries (compiled on Jetson Tk1 version 5.0) onto a different Jetson (L4T 4.0). it failed. :(
i also checked whether it a opencv problem or something else. So i created a simple code based on opencv build it on different version Jetson TK1 and ran it on different version Jetson TK1 it worked, means Opencv is working fine.
Now i don’t know what is happening when i compile my Person Detection application.It’s behaving weired.
Every time i get the same kind of error.
Don’t know what is the problem…its frustrating.
Kindly help on this.
