Everytime I ran the libArgus sample “Camera” app, at startup, it will set both the exposure and analog gain value to max. Is there a way to configure libArgus or nvcamera deamon to not do this?
thx!
thx!
You may try --aelock=1 with argus_camera for disabling auto-exposure.
There are many options, I’m not familiar with this, but you may check https://devtalk.nvidia.com/default/topic/992898/jetson-tx1/acquisition-at-120fps-using-libargus-not-working/post/5142454/#5142454
With gstreamer, nvcamerasrc also has a property auto-exposure that should be set off with auto-exposure=1 and lock property aeLock that can be set to true:
gst-inspect-1.0 nvcamerasrc
I tried that and also the exposure range, but it does not change it. I wonder if this is some configuration settings thing.
