So my install is a little weird. When running the installers for 64bit on the website, I initially could not get X to not go into low-resolution mode.
Running EnvyNG with 173.xx driver seemed to configure X properly. Then I reran the 177.67 installer for the driver and installed the toolkit and the SDK.
However, I cannot seem to find the libcuda file. However I seem to have all the other libraries in /usr/local/cuda/lib
Any suggestions on where I can grab and copy in a libcuda.so?
libcuda.so ships with the official display driver package. If you’re not using the official 177.67 display driver package from NVIDIA’s website, then you either need to contact whomever built your display driver package, or use the official package.
