**• Hardware Platform (Jetson / GPU)**T4
• DeepStream Version5.0
• TensorRT Version7.0
**• NVIDIA GPU Driver Version (valid for GPU only)**440.33.01
deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
libEGL warning: DRI3: failed to query the version
libEGL warning: DRI2: failed to authenticate
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:07.445803279 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 6]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:07.445883418 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 6]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:07.447841697 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
0:00:07.484123151 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 5]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:07.484169449 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 5]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:07.485663489 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
0:00:07.509080883 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:07.509126484 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:07.510591935 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:00:07.539116348 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:07.539160219 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:07.540057582 2940 0x55c5b5c9f6f0 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
