NVIDIA A30: libEGL warning: DRI3: Screen seems not DRI3 capable
unable to get display with EGLSINK.
tried xhost + before docker run
docker run command: sudo docker run --rm -it --gpus all -v ~/.Xauthority:/root/.Xauthority:ro -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY --network host -p 8181:8181 nvcr.io/nvidia/deepstream:5.1-21.02-triton
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 495
• Issue Type( questions, new requirements, bugs) EGLsink not working
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) python3 deepstream_test_1.py …/…/…/…/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file …/…/…/…/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
libEGL warning: DRI2: failed to authenticate
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:08.049060546 83 0x1925550 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:08.049090369 83 0x1925550 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/apps/deepstream-test1/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:08.049103209 83 0x1925550 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:19.553243796 83 0x1925550 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:19.562619913 83 0x1925550 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number=0 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:19.824906382 83 0x187f770 WARN nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:19.824922074 83 0x187f770 WARN nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(1984): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Please update your display driver to correct version.
