PC: A2000 12GB
Deepstream: 6.2
Driver Version: 550.120
Docker image: http://nvcr.io/nvidia/deepstream:6.2-devel
Monitor: not connected
I am trying to run deepstream-app in DS 6.2 in the above host PC with EGL sink and I am encountering the error below, with eglsink showing a black screen and application quitting immediately.
libEGL warning: DRI3: Screen seems not DRI3 capable
libEGL warning: DRI2: failed to authenticate
streaming stopped, reason not-negotiated (-4)
Steps to reproduce
sudo xhost +
docker run -it --gpus all -e DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix --entrypoint "/bin/bash" nvcr.io/nvidia/deepstream:6.2-devel
Modify a deepstream-app config with EGL sink and run the default deepstream-app.
Some additional Info about the PC
After running the docker run command echo Display inside the container shows “:1”
Furthermore here are some host info
lspci | grep -i vga
0000:03:00.0 VGA compatible controller: Matrox Electronics Systems Ltd. Integrated Matrox G200eW3 Graphics Controller (rev 04)
0000:17:00.0 VGA compatible controller: NVIDIA Corporation GA106 [RTX A2000 12GB] (rev a1)
*-display
description: VGA compatible controller
product: Integrated Matrox G200eW3 Graphics Controller
vendor: Matrox Electronics Systems Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: /dev/fb0
version: 04
width: 32 bits
clock: 66MHz
capabilities: pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=mgag200 latency=64 maxlatency=32 mingnt=16 resolution=1024,768
resources: irq:16 memory:94000000-94ffffff memory:95808000-9580bfff memory:95000000-957fffff memory:c0000-dffff
*-display
product: GA106 [RTX A2000 12GB]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:17:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: iomemory:21ff0-21fef iomemory:21ff0-21fef irq:193 memory:96000000-96ffffff memory:21ffe0000000-21ffefffffff memory:21fff0000000-21fff1ffffff ioport:4000(size=128) memory:97080000-970fffff
Additional context if I try with “nvcr.io/nvidia/deepstream:6.4-gc-triton-devel” I still get the same error libEGL warning, however the EGLsink still shows the video correctly
