Libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
system: Ubuntu 22.04.3 LTS
image : nvcr.io/nvidia/deepstream 6.4-triton-multiarch 1d7efdfc6c1a 10 months ago 13.4GB
how to run : docker run -it --rm --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix --privileged 1d7efdfc6c1a
Reference Documents:deepstream_python_apps/bindings at v1.1.10 · NVIDIA-AI-IOT/deepstream_python_apps
When I operated on cmake:
root@runone-PC:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build# cmake ..  -DPIP_PLATFORM=linux_aarch64
-- The C compiler identification is GNU 11.4.0
-- The CXX compiler identification is GNU 11.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at CMakeLists.txt:92 (message):
  Missing libnvbufsurface.so at
  /opt/nvidia/deepstream/deepstream/lib/libnvbufsurface.so
  please make sure that deepstream is installed
Call Stack (most recent call first):
  CMakeLists.txt:102 (add_ds_lib)
The above are errors related to Python building
If I run a native example:
cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test3
./deepstream-test3-app file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
0:00:00.008832673 10791 0xaaac5ec97f80 WARN     GST_ELEMENT_FACTORY gstelementfactory.c:754:gst_element_factory_make_valist: no such element factory "nvstreammux"!
One element could not be created. Exiting.
root@runone-PC:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test3# export GST_DEBUG=4
root@runone-PC:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test3# ./deepstream-test3-app file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
0:00:00.000049841 10793 0xaaad428c8200 INFO                GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.000088591 10793 0xaaad428c8200 INFO                GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000101961 10793 0xaaad428c8200 INFO                GST_INIT gst.c:611:init_pre: Linux runone-PC 4.19.0-arm64-server #5015 SMP Wed Feb 16 17:15:10 CST 2022 aarch64
0:00:00.000293562 10793 0xaaad428c8200 INFO                GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.000635015 10793 0xaaad428c8200 INFO                GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.000769386 10793 0xaaad428c8200 INFO      GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000841596 10793 0xaaad428c8200 INFO      GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.000851806 10793 0xaaad428c8200 INFO      GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.000876897 10793 0xaaad428c8200 INFO            GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.007461344 10793 0xaaad428c8200 INFO            GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.006563 seconds
0:00:00.007497534 10793 0xaaad428c8200 INFO            GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.008915354 10793 0xaaad428c8200 INFO            GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.008929864 10793 0xaaad428c8200 INFO            GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.008938264 10793 0xaaad428c8200 INFO                GST_INIT gst.c:833:init_post: GLib runtime version: 2.72.4
0:00:00.008945344 10793 0xaaad428c8200 INFO                GST_INIT gst.c:835:init_post: GLib headers version: 2.72.1
0:00:00.008951945 10793 0xaaad428c8200 INFO                GST_INIT gst.c:837:init_post: initialized GStreamer successfully
0:00:00.008987865 10793 0xaaad428c8200 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "pipeline"
0:00:00.009037915 10793 0xaaad428c8200 WARN     GST_ELEMENT_FACTORY gstelementfactory.c:754:gst_element_factory_make_valist: no such element factory "nvstreammux"!
Can you provide some relevant ideas? Thank you.
Is your server’s CPU an ARM architecture?
For docker user, There is a script to install pyds
/opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh  -r v1.1.10 -b
yes.
uname -r
4.19.0-arm64-server
This script is very convenient to follow Python Pyds, thank you
but I don’t think this script can solve the problem of libnvbufsurface.so being lost.
I just tried this script, and the final error is as follows
t-python/gi/overrides/GstAudio.py to /usr/local/local/lib/python3.10/dist-packages/gi/overrides
CMake Error at CMakeLists.txt:89 (message):
  CMakeLists.txt:99 (add_ds_lib)
-- Configuring incomplete, errors occurred!
See also "/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build/CMakeFiles/CMakeOutput.log".
make: *** No targets specified and no makefile found.  Stop.
Installing built PyDS wheel
WARNING: Requirement './pyds-1*_aarch64.whl' looks like a filename, but the file does not exist
ERROR: pyds-1*_aarch64.whl is not a valid wheel filename.  ```
Because DS-6.4 does not support arm server, it is recommended that you try DS-7.0 version and start docker in the following way.
docker run -it --rm --runtime=nvidia --network=host -e NVIDIA_DRIVER_CAPABILITIES=compute,utility,video,graphics --gpus all --privileged -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v /etc/X11:/etc/X11 nvcr.io/nvidia/deepstream:7.0-triton-arm-sbsa
NVIDIA Container Toolkit must be installed
https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/latest/install-guide.html
I don’t quite understand the relevant adaptation situation of DeepStream 6.4. From the official documentation, it seems that it supports ARM architecture. So when you say DS-6.4 does not support ARM server, does it mean that DS-6.4 has not been validated on ARM servers?
That refers to the jetson platform, the GPU is part of the SOC, not the ARM + dGPU model.
So I recommend you to use DS-7.0
After pulling and running the new image,
nvcr.io/nvidia/deepstream 7.0-triton-arm-sbsa 28df060f687c 5 months ago 26.7GB
And Then
/opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh  -r v1.1.11 -b
A large string of prints appeared, and I am not sure if this is a successful build…
-- Build files have been written to: /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/utils.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindmeta360.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindanalyticsmeta.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindfunctions.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/pyds.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindgstnvdsmeta.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindnvbufsurface.cpp.o
[ 81%] Building CXX object CMakeFiles/pyds.dir/src/custom_binding/bindcustom.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsinfer.cpp.o
[ 81%] Building CXX object CMakeFiles/pyds.dir/src/bindschema.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindopticalflow.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsmeta.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindnvosd.cpp.o
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:16,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/attr.h:13,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pybind11.h:44,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bind_string_property_definitions.h:18,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:20:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/detail/internals.h: In function 'pybind11::detail::internals& pybind11::detail::get_internals()':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/detail/internals.h:276:27: warning: 'void PyEval_InitThreads()' is deprecated [-Wdeprecated-declarations]
  276 |         PyEval_InitThreads();
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:20:
In file included from /usr/include/python3.10/Python.h:130,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/detail/common.h:112,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pytypes.h:12,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:13,
/usr/include/python3.10/ceval.h:122:37: note: declared here
  122 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindanalyticsmeta.hpp:20,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/pyds.cpp:19:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindgstnvdsmeta.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:18:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindanalyticsmeta.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindopticalflow.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvosd.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/pyds.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvbufsurface.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindmeta360.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindmeta360.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvdsinfer.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsinfer.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:35,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:28:
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:35,
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h: At global scope:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:403:31: warning: declaration of 'bool pybind11::detail::isinstance_generic(pybind11::handle, const std::type_info&)' with attribute 'noinline' follows inline declaration [-Wattributes]
  403 | PYBIND11_NOINLINE inline bool isinstance_generic(handle obj, const std::type_info &tp) {
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:13,
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pytypes.h:26:13: note: previous declaration of 'bool pybind11::detail::isinstance_generic(pybind11::handle, const std::type_info&)' here
   26 | inline bool isinstance_generic(handle obj, const std::type_info &tp);
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/cast.h:410:38: warning: declaration of 'std::string pybind11::detail::error_string()' with attribute 'noinline' follows inline declaration [-Wattributes]
  410 | PYBIND11_NOINLINE inline std::string error_string() {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/../3rdparty/pybind11/include/pybind11/pytypes.h:315:20: note: previous declaration of 'std::string pybind11::detail::error_string()' here
  315 | inline std::string error_string();
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp: In function 'pybind11::arg pydeepstream::operator""_a(const char*, size_t)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:48:57: warning: unused parameter 'len' [-Wunused-parameter]
   48 |     pybind11::arg operator ""_a(const char *str, size_t len) {
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/pyds.hpp:34,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindtrackermeta.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:21:
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer.h: At global scope:
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer.h:290:28: warning: missing initializer for member 'NvDsInferDims::d' [-Wmissing-field-initializers]
  290 |     NvDsInferDims dims = {0};
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer.h:290:28: warning: missing initializer for member 'NvDsInferDims::numElements' [-Wmissing-field-initializers]
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvdsmeta.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindanalyticsmeta.hpp:23,
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp: In lambda function:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:204:49: warning: unused parameter 'self' [-Wunused-parameter]
  204 |                               [](NvDsBatchMeta &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:217:49: warning: unused parameter 'self' [-Wunused-parameter]
  217 |                               [](NvDsBatchMeta &self) {});
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:271:49: warning: unused parameter 'self' [-Wunused-parameter]
  271 |                               [](NvDsFrameMeta &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:284:49: warning: unused parameter 'self' [-Wunused-parameter]
  284 |                               [](NvDsBatchMeta &self) {});
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:339:50: warning: unused parameter 'self' [-Wunused-parameter]
  339 |                               [](NvDsObjectMeta &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:352:50: warning: unused parameter 'self' [-Wunused-parameter]
  352 |                               [](NvDsObjectMeta &self) {});
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:28:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp: In instantiation of 'typename pydeepstream::utils::function_storage<UniqueName, RetValue, ArgTypes>::pointer_type pydeepstream::utils::free_fn_ptr_from_std_function(const std::function<RetValue(ArgTypes ...)>&) [with const char* UniqueName = (& pydeepstream::utils::copyfuncname); RetValue = void*; ArgTypes = {void*, void*}; typename pydeepstream::utils::function_storage<UniqueName, RetValue, ArgTypes>::pointer_type = void* (*)(void*, void*)]':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:88:45:   required from here
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:171:5: warning: no return statement in function returning non-void [-Wreturn-type]
  171 |     }
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:168:79: warning: unused parameter 'f' [-Wunused-parameter]
  168 |     free_fn_ptr_from_std_function(const std::function<RetValue(ArgTypes...)> &f) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp: In instantiation of 'typename pydeepstream::utils::function_storage<UniqueName, RetValue, ArgTypes>::pointer_type pydeepstream::utils::free_fn_ptr_from_std_function(const std::function<RetValue(ArgTypes ...)>&) [with const char* UniqueName = (& pydeepstream::utils::freefuncname); RetValue = void; ArgTypes = {void*, void*}; typename pydeepstream::utils::function_storage<UniqueName, RetValue, ArgTypes>::pointer_type = void (*)(void*, void*)]':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:89:52:   required from here
  171 |     }
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:500:51: warning: unused parameter 'self' [-Wunused-parameter]
  500 |                               [](NvDsDisplayMeta &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:513:51: warning: unused parameter 'self' [-Wunused-parameter]
  513 |                               [](NvDsDisplayMeta &self) {});
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/include/bindcustom.hpp:20,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindgstnvdsmeta.hpp:20,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindgstnvdsmeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindschema.hpp:23,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindopticalflow.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindopticalflow.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindanalyticsmeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindfunctions.hpp:27,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:19:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvosd.hpp:21,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvosd.cpp:22:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp: In function 'NvDsEventMsgMeta* pydeepstream::event_msg_meta_copy_func(void*, void*)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp:27:67: warning: unused parameter 'user_data' [-Wunused-parameter]
   27 |     NvDsEventMsgMeta * event_msg_meta_copy_func(void* data, void* user_data) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp: In function 'void pydeepstream::event_msg_meta_release_func(void*, void*)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp:107:58: warning: unused parameter 'user_data' [-Wunused-parameter]
  107 |     void event_msg_meta_release_func(void * data, void * user_data) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp: In function 'CustomDataStruct* pydeepstream::copy_custom_struct(void*, void*)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:27:61: warning: unused parameter 'user_data' [-Wunused-parameter]
   27 |     CustomDataStruct * copy_custom_struct(void* data, void* user_data) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp: In function 'void pydeepstream::release_custom_struct(void*, void*)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:48:24: warning: unused variable 'message' [-Wunused-variable]
   48 |                 auto * message = srcData->message;
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:43:52: warning: unused parameter 'user_data' [-Wunused-parameter]
   43 |     void release_custom_struct(void * data, void * user_data) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp: In lambda function:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:191:59: warning: unused parameter 'self' [-Wunused-parameter]
  191 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp: In lambda function:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:552:60: warning: unused parameter 'func' [-Wunused-parameter]
  552 |               [](std::function<utils::COPYFUNC_SIG> const &func) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:204:59: warning: unused parameter 'self' [-Wunused-parameter]
  204 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:575:63: warning: unused parameter 'func' [-Wunused-parameter]
  575 |               [](std::function<utils::RELEASEFUNC_SIG> const &func) {
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:217:59: warning: unused parameter 'self' [-Wunused-parameter]
  217 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsinfer.cpp: In lambda function:
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsinfer.cpp:45:49: warning: unused parameter 'self' [-Wunused-parameter]
   45 |                               [](NvDsInferDims &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:230:59: warning: unused parameter 'self' [-Wunused-parameter]
  230 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:673:47: warning: 'void* g_memdup(gconstpointer, guint)' is deprecated: Use 'g_memdup2' instead [-Wdeprecated-declarations]
  673 |                       return (size_t) g_memdup(buffer, size);
In file included from /usr/include/glib-2.0/glib.h:82,
                 from /usr/include/gstreamer-1.0/gst/gst.h:27,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindfunctions.hpp:26,
/usr/include/glib-2.0/glib/gstrfuncs.h:257:23: note: declared here
  257 | gpointer              g_memdup         (gconstpointer mem,
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp: In function 'void pydeepstream::bindfunctions(pybind11::module&)':
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:683:15: warning: cast between incompatible function types from 'int (*)(NvBufSurface**, uint32_t, NvBufSurfaceCreateParams*)' {aka 'int (*)(NvBufSurface**, unsigned int, NvBufSurfaceCreateParams*)'} to 'int (*)(NvBufSurface*, int, NvBufSurfaceCreateParams)' [-Wcast-function-type]
  683 |               (int (*)(NvBufSurface *, int,
  684 |                        NvBufSurfaceCreateParams)) &NvBufSurfaceCreate,
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:243:59: warning: unused parameter 'self' [-Wunused-parameter]
  243 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:256:59: warning: unused parameter 'self' [-Wunused-parameter]
  256 |                               [](NvBufSurfacePlaneParams &self) {})
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:317:58: warning: unused parameter 'self' [-Wunused-parameter]
  317 |                               [](NvBufSurfaceMappedAddr &self) {})
[ 93%] Linking CXX shared library pyds.so
[ 93%] Built target pyds
[100%] Generating pyds-1.1.11-py3-none-linux_aarch64.whl
WARNING: '' not a valid package name; please use only .-separated package names in setup.py
running bdist_wheel
running build
running build_py
creating build
creating build/lib
copying pyds.so -> build/lib
/usr/local/lib/python3.10/dist-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
        Please avoid running ``setup.py`` directly.
        Instead, use pypa/build, pypa/installer or other
        standards-based tools.
        See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
  self.initialize_options()
installing to build/bdist.linux-aarch64/wheel
running install
running install_lib
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/wheel
copying build/lib/pyds.so -> build/bdist.linux-aarch64/wheel
running install_egg_info
running egg_info
creating pyds.egg-info
writing pyds.egg-info/PKG-INFO
writing dependency_links to pyds.egg-info/dependency_links.txt
writing requirements to pyds.egg-info/requires.txt
writing top-level names to pyds.egg-info/top_level.txt
writing manifest file 'pyds.egg-info/SOURCES.txt'
reading manifest file 'pyds.egg-info/SOURCES.txt'
Copying pyds.egg-info to build/bdist.linux-aarch64/wheel/pyds-1.1.11-py3.10.egg-info
running install_scripts
creating build/bdist.linux-aarch64/wheel/pyds-1.1.11.dist-info/WHEEL
creating 'dist/pyds-1.1.11-py3-none-linux_aarch64.whl' and adding 'build/bdist.linux-aarch64/wheel' to it
adding 'pyds.so'
adding 'pyds-1.1.11.dist-info/METADATA'
adding 'pyds-1.1.11.dist-info/WHEEL'
adding 'pyds-1.1.11.dist-info/top_level.txt'
adding 'pyds-1.1.11.dist-info/RECORD'
removing build/bdist.linux-aarch64/wheel
[100%] Built target pip_wheel
But at least the following will not cause errors:
import pyds
import cuda
And then
vim Makefile : CUDA_VER?=12.2
vim deepstream_test3_app.c :
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  if (PERF_MODE) {
    sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
  } else {
    /* Finally render the osd output */
    if(prop.integrated) {
      sink = gst_element_factory_make ("fakesink", "fakesink");
    } else {
#ifdef __aarch64__
      sink = gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
#else
      sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
#endif
make and run:
0:00:00.000077491 12751 0xaaae96798670 INFO                GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.000117181 12751 0xaaae96798670 INFO                GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000129401 12751 0xaaae96798670 INFO                GST_INIT gst.c:611:init_pre: Linux runone-PC 4.19.0-arm64-server #5015 SMP Wed Feb 16 17:15:10 CST 2022 aarch64
0:00:00.000313323 12751 0xaaae96798670 INFO                GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.000631435 12751 0xaaae96798670 INFO                GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.000777286 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000838417 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.000847857 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.000884817 12751 0xaaae96798670 INFO            GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.012818399 12751 0xaaae96798670 INFO            GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.011907 seconds
0:00:00.012860179 12751 0xaaae96798670 INFO            GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.014452711 12751 0xaaae96798670 INFO            GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.014468362 12751 0xaaae96798670 INFO            GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.014476982 12751 0xaaae96798670 INFO                GST_INIT gst.c:833:init_post: GLib runtime version: 2.76.6
0:00:00.014484982 12751 0xaaae96798670 INFO                GST_INIT gst.c:835:init_post: GLib headers version: 2.72.1
0:00:00.014490632 12751 0xaaae96798670 INFO                GST_INIT gst.c:837:init_post: initialized GStreamer successfully
0:00:00.014528262 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "pipeline"
0:00:00.017185983 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.017343624 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvstreammux"
0:00:00.017380404 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstNvStreamMux@0xaaae96a5f2b0> adding pad 'src'
0:00:00.017426984 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "bin"
0:00:00.018050659 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstplayback.so" loaded
0:00:00.018121480 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "uridecodebin"
0:00:00.018182700 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<source-bin-00> adding pad 'src'
0:00:00.018204280 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:1013:gst_element_get_static_pad: no such pad 'sink_0' in element "stream-muxer"
0:00:00.018230421 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<stream-muxer> adding pad 'sink_0'
0:00:00.018239691 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad source-bin-00:src
0:00:00.018254461 12751 0xaaae96798670 INFO                GST_PADS gstpad.c:2382:gst_pad_link_prepare: trying to link source-bin-00:src and stream-muxer:sink_0
0:00:00.018268301 12751 0xaaae96798670 INFO                GST_PADS gstpad.c:4357:gst_pad_peer_query:<src:proxypad0> pad has no peer
0:00:00.018284391 12751 0xaaae96798670 INFO                GST_PADS gstpad.c:4357:gst_pad_peer_query:<stream-muxer:src> pad has no peer
0:00:00.018308221 12751 0xaaae96798670 INFO                GST_PADS gstpad.c:2590:gst_pad_link_full: linked source-bin-00:src and stream-muxer:sink_0, successful
0:00:00.018314771 12751 0xaaae96798670 INFO               GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018321821 12751 0xaaae96798670 INFO               GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:<source-bin-00:src> Received event on flushing pad. Discarding
0:00:00.056830798 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so" loaded
0:00:00.057008369 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvinfer"
0:00:00.057036859 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96f96090> adding pad 'sink'
0:00:00.057051869 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96f96090> adding pad 'src'
0:00:00.057555243 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.057620724 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "queue"
0:00:00.057640354 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96facfa0> adding pad 'sink'
0:00:00.057655944 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96facfa0> adding pad 'src'
0:00:00.057668194 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "queue"
0:00:00.057683184 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96faf7d0> adding pad 'sink'
0:00:00.057706874 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96faf7d0> adding pad 'src'
0:00:00.057717685 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "queue"
0:00:00.057731575 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb20a0> adding pad 'sink'
0:00:00.057744585 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb20a0> adding pad 'src'
0:00:00.057753755 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "queue"
0:00:00.057766975 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb4a80> adding pad 'sink'
0:00:00.057779455 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb4a80> adding pad 'src'
0:00:00.057788545 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "queue"
0:00:00.057801715 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb7460> adding pad 'sink'
0:00:00.057814565 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstQueue@0xaaae96fb7460> adding pad 'src'
0:00:00.058023427 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_logger.so" loaded
0:00:00.058082777 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvdslogger"
0:00:00.058098077 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fbb9b0> adding pad 'sink'
0:00:00.058110218 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fbb9b0> adding pad 'src'
0:00:00.058563021 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so" loaded
0:00:00.058644632 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvmultistreamtiler"
0:00:00.058661762 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fc0720> adding pad 'sink'
0:00:00.058673252 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fc0720> adding pad 'src'
0:00:00.058685732 12751 0xaaae96798670 WARN     GST_ELEMENT_FACTORY gstelementfactory.c:754:gst_element_factory_make_valist: no such element factory "nvvideoconvert"!
0:00:00.063488169 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so" loaded
0:00:00.063582280 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvdsosd"
0:00:00.063600990 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fdb360> adding pad 'sink'
0:00:00.063614190 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseTransform@0xaaae96fdb360> adding pad 'src'
0:00:00.064254555 12751 0xaaae96798670 INFO      GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so" loaded
0:00:00.064367756 12751 0xaaae96798670 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nv3dsink"
0:00:00.064389736 12751 0xaaae96798670 INFO        GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstBaseSink@0xaaae9709df00> adding pad 'sink'
Finally, when running the native example, the above error occurred. At the same time, when executing user_deepstream_python-apps_install.sh, a lot of printing appeared, but I couldn’t tell if it was successfully executed. Can you give me some ideas? Thank you.
if I try :
python3 deepstream_test_1.py file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
/bin/bash: line 1: lsmod: command not found
/bin/bash: line 1: modprobe: command not found
0:00:00.081588341 12961 0xaaaeb68be880 WARN     GST_ELEMENT_FACTORY gstelementfactory.c:754:gst_element_factory_make_valist: no such element factory "nvvideoconvert"!
 Unable to create nvvidconv
Is it Integrated GPU? : 0
Creating nv3dsink
Playing file file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Adding elements to Pipeline
  File "/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py", line 263, in <module>
    sys.exit(main(sys.argv))
  File "/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py", line 214, in main
    pipeline.add(nvvidconv)
  File "/usr/lib/python3/dist-packages/gi/overrides/Gst.py", line 72, in add
    if not Gst.Bin.add(self, arg):
TypeError: Argument 1 does not allow None as a value
pyds has been installed correctly.
It’s the same question, Let’s look at the native first.
What is the output of the following command line ?
ldd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so
Maybe it was a network issue before? I deleted deepstream_python-apps and then re executed:
Then I tried again:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating nv3dsink
Linking elements in the Pipeline
Starting pipeline
libEGL warning: DRI2: failed to authenticate
0:00:01.549596294 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549629774 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:01.549637974 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549646085 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:01.549673835 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549681915 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat AV10
0:00:01.549688085 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549695655 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat AV10
0:00:01.549711265 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549718435 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:01.549725355 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549732405 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:01.549745485 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549753495 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:01.549759805 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549766715 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:01.549779846 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549787216 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:01.549792956 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549799576 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:01.549811026 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549819046 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:01.549825256 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549831826 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:01.549846526 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549854976 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H265
0:00:01.549860786 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549867186 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H265
0:00:01.549878246 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549885016 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP90
0:00:01.549890826 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549897206 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP90
0:00:01.549908107 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549914227 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP80
0:00:01.549920377 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549926197 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP80
0:00:01.549939267 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549947127 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H264
0:00:01.549953427 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:01.549961197 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H264
0:00:01.550441151 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550449951 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat Y444
0:00:01.550456181 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550462961 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat Y444
0:00:01.550479021 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550486781 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat P410
0:00:01.550492491 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550499001 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat P410
0:00:01.550512161 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550519731 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat PM10
0:00:01.550525411 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550531761 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat PM10
0:00:01.550544881 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550552061 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat NM12
0:00:01.550557721 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:01.550563872 17128 0xaaad18d577f0 WARN                    v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat NM12
0:00:09.039940498 17128 0xaaad18d577f0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x544x960
1   OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2   OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:09.236185221 17128 0xaaad18d577f0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
0:00:09.292771151 17128 0xaaad18d577f0 INFO                 nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
0:00:09.294739866 17128 0xaaad18d577f0 WARN                 filesrc gstfilesrc.c:553:gst_file_src_start:<file-source> error: No such file "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264"
0:00:09.294774456 17128 0xaaad18d577f0 WARN                 basesrc gstbasesrc.c:3556:gst_base_src_start:<file-source> error: Failed to start
0:00:09.294907997 17128 0xaaad18d577f0 WARN                 filesrc gstfilesrc.c:553:gst_file_src_start:<file-source> error: No such file "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264"
0:00:09.294924247 17128 0xaaad18d577f0 WARN                 basesrc gstbasesrc.c:3556:gst_base_src_start:<file-source> error: Failed to start
0:00:09.294940368 17128 0xaaad18d577f0 WARN                 basesrc gstbasesrc.c:3912:gst_base_src_activate_push:<file-source> Failed to start in push mode
0:00:09.294961178 17128 0xaaad18d577f0 WARN                GST_PADS gstpad.c:1141:gst_pad_set_active:<file-source:src> Failed to activate pad
Error: gst-resource-error-quark: Resource not found. (3): ../plugins/elements/gstfilesrc.c(553): gst_file_src_start (): /GstPipeline:pipeline0/GstFileSrc:file-source:
Does it look like the previous mistake has been resolved?
And Then :
        linux-vdso.so.1 (0x0000fffbdd4c0000)
        libgstbase-1.0.so.0 => /lib/aarch64-linux-gnu/libgstbase-1.0.so.0 (0x0000fffbdd320000)
        libgstreamer-1.0.so.0 => /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 (0x0000fffbdd1b0000)
        libglib-2.0.so.0 => /lib/aarch64-linux-gnu/libglib-2.0.so.0 (0x0000fffbdd050000)
        libgobject-2.0.so.0 => /lib/aarch64-linux-gnu/libgobject-2.0.so.0 (0x0000fffbdcfd0000)
        libgstvideo-1.0.so.0 => /lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 (0x0000fffbdcee0000)
        libnvdsbufferpool.so.1.0.0 => /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0 (0x0000fffbdcec0000)
        libnvbufsurftransform.so.1.0.0 => /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0 (0x0000fffbda3b0000)
        libnvbufsurface.so.1.0.0 => /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0 (0x0000fffbda2e0000)
        libnvdsgst_meta.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_meta.so (0x0000fffbda2c0000)
        libnvdsgst_helper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_helper.so (0x0000fffbda2a0000)
        libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000fffbda0f0000)
        /lib/ld-linux-aarch64.so.1 (0x0000fffbdd4d0000)
        libgmodule-2.0.so.0 => /lib/aarch64-linux-gnu/libgmodule-2.0.so.0 (0x0000fffbda0d0000)
        libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000fffbda030000)
        libunwind.so.8 => /lib/aarch64-linux-gnu/libunwind.so.8 (0x0000fffbd9ff0000)
        libdw.so.1 => /lib/aarch64-linux-gnu/libdw.so.1 (0x0000fffbd9f30000)
        libpcre2-8.so.0 => /lib/aarch64-linux-gnu/libpcre2-8.so.0 (0x0000fffbd9e90000)
        libffi.so.8 => /lib/aarch64-linux-gnu/libffi.so.8 (0x0000fffbd9e70000)
        liborc-0.4.so.0 => /lib/aarch64-linux-gnu/liborc-0.4.so.0 (0x0000fffbd9dd0000)
        libcuda.so.1 => /lib/aarch64-linux-gnu/libcuda.so.1 (0x0000fffbd8190000)
        libstdc++.so.6 => /lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000fffbd7f60000)
        libnvrm_mem.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_mem.so (0x0000fffbd7f40000)
        libnvrm_surface.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_surface.so (0x0000fffbd7f20000)
        libnvrm_chip.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_chip.so (0x0000fffbd7f00000)
        libEGL.so.1 => /lib/aarch64-linux-gnu/libEGL.so.1 (0x0000fffbd7ed0000)
        libnvos.so => /usr/lib/aarch64-linux-gnu/tegra/libnvos.so (0x0000fffbd7eb0000)
        libnvbuf_fdmap.so.1.0.0 => /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_fdmap.so.1.0.0 (0x0000fffbd7e90000)
        libnvds_meta.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_meta.so (0x0000fffbd7e70000)
        libgstrtp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstrtp-1.0.so.0 (0x0000fffbd7e30000)
        liblzma.so.5 => /lib/aarch64-linux-gnu/liblzma.so.5 (0x0000fffbd7df0000)
        libelf.so.1 => /lib/aarch64-linux-gnu/libelf.so.1 (0x0000fffbd7dc0000)
        libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000fffbd7d90000)
        libbz2.so.1.0 => /lib/aarch64-linux-gnu/libbz2.so.1.0 (0x0000fffbd7d60000)
        libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000fffbd7d40000)
        librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000fffbd7d20000)
        libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000fffbd7d00000)
        libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000fffbd7cd0000)
        libGLdispatch.so.0 => /lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x0000fffbd7b40000)
Reinstalling pyds usually has no impact on nvvideoconvert.Do you have other actions?
Did you delete this file?
The file exists
ll /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
-rw-r--r-- 1 root root 14759548 Apr 28 23:19 /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
I also installed kmod separately: apt get install kmod,
because I saw in the error that the lsmod related command does not exist
This error usually has no impact.
Try the following command line.
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
For test_1.py, source element is filesrc, it only accepts path as arguments.
For test_3.py source element is uridecodebin, Only uri is a valid parameter.
Please read README first.
Thank you very much, the pipeline is now running normally
