• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version 8.5.2
• Issue Type( questions, new requirements, bugs) Building DeepStream python bindings fails
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) I followed the readme file (deepstream_python_apps/bindings at v1.1.6 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub)
• Python version 3.8
I am trying to build DeepStream python bindings from scratch locally on NVIDIA Jetson Orin Nano ( I can’t work with docker container nor wheel installation).
I followed the readme file in the DeepStream_python_apps GitHub project (v1.1.6). The gst-python was not installed so I followed the deepstream_python_apps/HOWTO.md at v1.1.6 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub readme file for the installation with keeping in mind the aarch64 platform.
The bindings build till 81% and then throws these errors:
[ 81%] Building CXX object CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o
In file included from /opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/include/pyds.hpp:34,
from /opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/include/bind/bindtrackermeta.hpp:22,
from /opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:21:
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer.h:287:28: warning: missing initializer for member ‘NvDsInferDims::d’ [-Wmissing-field-initializers]
287 | NvDsInferDims dims = {0};
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer.h:287:28: warning: missing initializer for member ‘NvDsInferDims::numElements’ [-Wmissing-field-initializers]
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp: In function ‘void pydeepstream::bindtrackermeta(pybind11::module&)’:
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:29:20: error: ‘NvDsTargetMiscDataFrame’ was not declared in this scope
29 | py::class_<NvDsTargetMiscDataFrame>(m, "NvDsTargetMiscDataFrame",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:29:43: error: template argument 1 is invalid
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:32:45: error: ‘NvDsTargetMiscDataFrame’ is not a class, namespace, or enumeration
32 | .def_readwrite("frameNum", &NvDsTargetMiscDataFrame::frameNum)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:33:42: error: ‘NvDsTargetMiscDataFrame’ is not a class, namespace, or enumeration
33 | .def_readwrite("tBbox", &NvDsTargetMiscDataFrame::tBbox)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:34:47: error: ‘NvDsTargetMiscDataFrame’ is not a class, namespace, or enumeration
34 | .def_readwrite("confidence", &NvDsTargetMiscDataFrame::confidence)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:35:40: error: ‘NvDsTargetMiscDataFrame’ is not a class, namespace, or enumeration
35 | .def_readwrite("age", &NvDsTargetMiscDataFrame::age)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp: In lambda function:
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:39:34: error: ‘NvDsTargetMiscDataFrame’ is not captured
39 | return (NvDsTargetMiscDataFrame *) data;
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:38:23: note: the lambda has no capture-default
38 | [](void *data) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:29:20: note: ‘<typeprefixerror>NvDsTargetMiscDataFrame’ declared here
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:39:59: error: expected primary-expression before ‘)’ token
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:39:60: error: expected ‘;’ before ‘data’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:39:61: warning: statement has no effect [-Wunused-value]
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:45:20: error: ‘NvDsTargetMiscDataObject’ was not declared in this scope
45 | py::class_<NvDsTargetMiscDataObject>(m, "NvDsTargetMiscDataObject",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:45:44: error: template argument 1 is invalid
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:48:43: error: ‘NvDsTargetMiscDataObject’ is not a class, namespace, or enumeration
48 | .def_readwrite("numObj", &NvDsTargetMiscDataObject::numObj)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:49:45: error: ‘NvDsTargetMiscDataObject’ is not a class, namespace, or enumeration
49 | .def_readwrite("uniqueId", &NvDsTargetMiscDataObject::uniqueId)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:50:44: error: ‘NvDsTargetMiscDataObject’ is not a class, namespace, or enumeration
50 | .def_readwrite("classId", &NvDsTargetMiscDataObject::classId)
In file included from /opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:20:
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:52:49: error: ‘NvDsTargetMiscDataObject’ does not name a type
52 | STRING_CHAR_ARRAY(NvDsTargetMiscDataObject, objLabel))
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/include/bind/bind_string_property_definitions.h:48:18: note: in definition of macro ‘STRING_CHAR_ARRAY’
48 | [](const TYPE &self)->std::string { \
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/include/bind/bind_string_property_definitions.h:51:9: error: expected identifier before ‘[’ token
51 | [](TYPE &self, std::string str) { \
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:52:31: note: in expansion of macro ‘STRING_CHAR_ARRAY’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/include/bind/bind_string_property_definitions.h:51:11: error: expected ‘,’ or ‘...’ before ‘(’ token
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:54:17: error: expected ‘{’ before ‘.’ token
54 | .def("cast",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:54:18: error: ‘struct pydeepstream::bindtrackermeta(pybind11::module&)::<lambda(int, int*)>’ has no member named ‘def’
54 | .def("cast",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:56:34: error: ‘NvDsTargetMiscDataObject’ is not captured
56 | return (NvDsTargetMiscDataObject *) data;
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:55:23: note: the lambda has no capture-default
55 | [](void *data) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:45:20: note: ‘<typeprefixerror>NvDsTargetMiscDataObject’ declared here
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:56:60: error: expected primary-expression before ‘)’ token
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:56:61: error: expected ‘;’ before ‘data’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:56:62: warning: statement has no effect [-Wunused-value]
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:62:25: error: ‘NvDsTargetMiscDataObject’ is not a type
62 | [](NvDsTargetMiscDataObject &self) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:63:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
63 | return py::make_iterator(self.list,
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:64:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
64 | self.list + self.numObj);
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:64:68: error: request for member ‘numObj’ in ‘self’, which is of non-class type ‘int’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:70:20: error: ‘NvDsTargetMiscDataStream’ was not declared in this scope
70 | py::class_<NvDsTargetMiscDataStream>(m, "NvDsTargetMiscDataStream",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:70:44: error: template argument 1 is invalid
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:73:45: error: ‘NvDsTargetMiscDataStream’ is not a class, namespace, or enumeration
73 | .def_readwrite("streamID", &NvDsTargetMiscDataStream::streamID)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:75:33: error: ‘NvDsTargetMiscDataStream’ is not a class, namespace, or enumeration
75 | &NvDsTargetMiscDataStream::surfaceStreamID)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:77:33: error: ‘NvDsTargetMiscDataStream’ is not a class, namespace, or enumeration
77 | &NvDsTargetMiscDataStream::numAllocated)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:78:46: error: ‘NvDsTargetMiscDataStream’ is not a class, namespace, or enumeration
78 | .def_readwrite("numFilled", &NvDsTargetMiscDataStream::numFilled)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:82:34: error: ‘NvDsTargetMiscDataStream’ is not captured
82 | return (NvDsTargetMiscDataStream *) data;
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:81:23: note: the lambda has no capture-default
81 | [](void *data) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:70:20: note: ‘<typeprefixerror>NvDsTargetMiscDataStream’ declared here
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:82:60: error: expected primary-expression before ‘)’ token
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:82:61: error: expected ‘;’ before ‘data’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:82:62: warning: statement has no effect [-Wunused-value]
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:88:25: error: ‘NvDsTargetMiscDataStream’ is not a type
88 | [](NvDsTargetMiscDataStream &self) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:89:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
89 | return py::make_iterator(self.list,
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:90:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
90 | self.list + self.numFilled);
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:90:68: error: request for member ‘numFilled’ in ‘self’, which is of non-class type ‘int’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:96:20: error: ‘NvDsTargetMiscDataBatch’ was not declared in this scope
96 | py::class_<NvDsTargetMiscDataBatch>(m, "NvDsTargetMiscDataBatch",
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:96:43: error: template argument 1 is invalid
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:100:33: error: ‘NvDsTargetMiscDataBatch’ is not a class, namespace, or enumeration
100 | &NvDsTargetMiscDataBatch::numAllocated)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:101:46: error: ‘NvDsTargetMiscDataBatch’ is not a class, namespace, or enumeration
101 | .def_readwrite("numFilled", &NvDsTargetMiscDataBatch::numFilled)
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:105:34: error: ‘NvDsTargetMiscDataBatch’ is not captured
105 | return (NvDsTargetMiscDataBatch *) data;
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:104:23: note: the lambda has no capture-default
104 | [](void *data) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:96:20: note: ‘<typeprefixerror>NvDsTargetMiscDataBatch’ declared here
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:105:59: error: expected primary-expression before ‘)’ token
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:105:60: error: expected ‘;’ before ‘data’
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:105:61: warning: statement has no effect [-Wunused-value]
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:111:25: error: ‘NvDsTargetMiscDataBatch’ is not a type
111 | [](NvDsTargetMiscDataBatch &self) {
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:112:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
112 | return py::make_iterator(self.list,
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:113:56: error: request for member ‘list’ in ‘self’, which is of non-class type ‘int’
113 | self.list + self.numFilled);
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:113:68: error: request for member ‘numFilled’ in ‘self’, which is of non-class type ‘int’
make[2]: *** [CMakeFiles/pyds.dir/build.make:219: CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:105: CMakeFiles/pyds.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
deepstream-6.2 is installed correctly:
$ deepstream-app --version-all
deepstream-app version 6.2.0
DeepStreamSDK 6.2.0
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.5
cuDNN Version: 8.6
nvbufsurftransform: Could not get EGL display connection
libNVWarp360 Version: 2.0.1d3
Am I missing something? Should I link the libgstpython.so
Thank you,
Ahmed
