No such file nvds_analytics_meta.h when building python bindings
I have got an issue with the compilation of the python bindings for DeeoStream 6.0
Platform: Jetson Nano
DeepStream Version: 6.0 (using latest nvcr.io/nvidia/deepstream-l4t:6.0-base)
JetPack 4.5 (L4T R32.5.0)
Reproducing the issue:
  1. Run the deepstream container
    sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix
  2. Clone the deepstream_python_apps repo into /opt/nvidia/deepstream/deepstream-6.0
    git clone GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications
    cd deepstream_python_apps
  3. Follow the steps described under deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Dependencies for Ubuntu 18.04
apt install -y git python-dev python3 python3-pip python3.6-dev python3.8-dev cmake g++ build-essential
libglib2.0-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake
Submodule Init
git submodule update --init
For the Gst-Python section to work, additional dependencies hat do be installed
apt install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
Install Gst-Python
cd 3rdparty/gst-python/
./autogen.sh
make
make install
Build the bindings
cd deepstream_python_apps/bindings
mkdir build
cd build
cmake …
make
Here is where the make command yields an error:
In file included from /opt/nvidia/deepstream/deepstream-6.0/deepstream_python_apps/bindings/src/pyds.cpp:19:0:
/opt/nvidia/deepstream/deepstream-6.0/deepstream_python_apps/bindings/include/bind/bindanalyticsmeta.hpp:21:10: fatal error: nvds_analytics_meta.h: No such file or directory
Thank you in advance for every piece of advice
Note, DS6.0 must work on Jetpack4.6
