The following docker image works when using nvcr.io/nvidia/deepstream:6.2-devel as base image. However, when using nvcr.io/nvidia/deepstream:6.2-base it throws the following error:
Step 1/39 : FROM nvcr.io/nvidia/deepstream:6.2-base
---> 857f7a8f5cea
Step 2/39 : RUN apt update && apt install -y python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
---> Using cache
---> 6c1c9b892ca9
Step 3/39 : RUN apt update && apt install -y apt-transport-https ca-certificates
---> Using cache
---> 6b81032a1268
Step 4/39 : RUN update-ca-certificates
---> Using cache
---> 241ebf5aaf77
Step 5/39 : RUN mkdir -p /opt/nvidia/deepstream/deepstream-6.2/sources/apps && cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps && git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
---> Using cache
---> 3324c0bd75f2
Step 6/39 : RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps && git checkout 441b50da01779a2afacc60d40cd666d4bdde628e && git submodule update --init
---> Using cache
---> 3dfc82b45e86
Step 7/39 : RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/3rdparty/gst-python/ && ./autogen.sh && make && make install
---> Using cache
---> f42a849e0090
Step 8/39 : RUN pip3 install --upgrade pip
---> Using cache
---> f32f6990d65f
Step 9/39 : RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings && mkdir build && cd build && cmake .. && make && pip3 install pyds-1.1.6-py3-none-linux_x86_64.whl
---> Running in 36320e36a68b
-- The C compiler identification is GNU 9.4.0
-- The CXX compiler identification is GNU 9.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings/build
Scanning dependencies of target pyds
[ 6%] Building CXX object CMakeFiles/pyds.dir/src/pyds.cpp.o
In file included from /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings/src/pyds.cpp:19:
/opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings/include/bind/bindanalyticsmeta.hpp:21:10: fatal error: nvds_analytics_meta.h: No such file or directory
21 | #include "nvds_analytics_meta.h"
compilation terminated.
make[2]: *** [CMakeFiles/pyds.dir/build.make:63: CMakeFiles/pyds.dir/src/pyds.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:105: CMakeFiles/pyds.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
The command '/bin/sh -c cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings && mkdir build && cd build && cmake .. && make && pip3 install pyds-1.1.6-py3-none-linux_x86_64.whl' returned a non-zero code: 2
Makefile:4: recipe for target 'build' failed
make: *** [build] Error 2
Dockerfile causing the error:
# ENV GIT_SSL_NO_VERIFY=1
# SETUP PYTHON AND OTHER DEPENDENCIES
RUN apt update && apt install -y python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev \
python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \
# DEEPSTREAM PYTHON BINDINGS
RUN mkdir -p /opt/nvidia/deepstream/deepstream-6.2/sources/apps && \
cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps && \
RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps && \
git checkout 441b50da01779a2afacc60d40cd666d4bdde628e && \
RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/3rdparty/gst-python/ && \
./autogen.sh && \
make && \
make install
RUN cd /opt/nvidia/deepstream/deepstream-6.2/sources/apps/deepstream_python_apps/bindings && \
mkdir build && \
cd build && \
cmake .. && \
make && \
EDIT:
- I looked for the file using
find / -name nvds_analytics_meta.hbut I can’t find it. - Installing additional deepstream dependencies does not help:
cd /opt/nvidia/deepstream/deepstream-6.2 && bash user_additional_install.sh
