The following dockerfile was working fine a few months ago:
FROM nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
# DEEPSTREAM ADDITIONAL DEPENDENCIES
RUN cd /opt/nvidia/deepstream/deepstream-7.0 && \
bash user_additional_install.sh
# DEEPSTREAM PYTHON BINDINGS
RUN bash /opt/nvidia/deepstream/deepstream-7.0/user_deepstream_python_apps_install.sh -b
I tried to build the docker image today, and the second command is giving me an error:
[100%] Linking CXX shared library pyds.so
make[2]: Leaving directory '/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/bindings/build'
[100%] Built target pyds
make[1]: Leaving directory '/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/bindings/build'
Installing built PyDS wheel
WARNING: Requirement './pyds-1*_x86_64.whl' looks like a filename, but the file does not exist
ERROR: pyds-1*_x86_64.whl is not a valid wheel filename.
[notice] A new release of pip is available: 24.0 -> 24.2
[notice] To update, run: python3 -m pip install --upgrade pip
The full output is attached to this message because it was too long to be included here.
I also tried to update pip (see second output) but it is still not working.
GPU Tesla T4 • DeepStream Version
DeepStream 7.0 official docker image output_full_pip_updated.txt (95.9 KB) output_full.txt (97.1 KB)
Can you add --version 1.1.11 and try again?
If no version is specified, the script will pull the repo from master branch, which has upgrade to version 1.2.0 and it’s for DeepStream 7.1 recently, I think that’s the root cause.
My understanding is that if I pass the parameter --version 1.1.11, it will download binaries for 1.1.11. While if I pass parameter -b, it will build the latest binaries.
Is there a way to build version 1.1.11?
