Libnvdla_compiler.so: cannot open shared object file: No such file or directory
Hello everyone,
I’m facing some issues while trying to build my image through a Dockerfile, but my build fails with the following error:
“libnvdla_compiler.so: cannot open shared object file: No such file or directory”
I’m using an Jetson AGX (32GB) as host machine.
The starting image (FROM tag on my dockerfile) is “nvcr.io/nvidia/l4t-pytorch:r35.1.0-pth1.12-py3”, and I want to use also the torch2trt module, following the instructions here.
But when I try to execute the line
python3 setup.py install --plugins
I got the error:
  File "setup.py", line 2, in <module>
    import tensorrt
  File "/usr/lib/python3.8/dist-packages/tensorrt/__init__.py", line 68, in <module>
    from .tensorrt import *
ImportError: libnvdla_compiler.so: cannot open shared object file: No such file or directoryre
By any chance could you please support me?
We are moving this post to the Jetson AGX forum to get better help.
Thank you.
Hi @utente1161, can you set your default docker runtime to ‘nvidia’ before building your dockerfile? Like shown here: https://github.com/dusty-nv/jetson-containers#docker-default-runtime
Also, can you confirm that you have these drivers/libraries on your device? (outside of container)
ls -ll /usr/lib/aarch64-linux-gnu/tegra/libnvdla*
-rw-r--r-- 1 root root 5954264 May 17  2022 /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so
-rw-r--r-- 1 root root  392488 May 17  2022 /usr/lib/aarch64-linux-gnu/tegra/libnvdla_runtime.so
  1. Try adding a file /etc/ld.so.conf.d/nvidia-tegra.conf with the following content
  1. run “sudo ldconfig”
Now try again your command
