• Hardware Platform (Jetson / GPU) RTX3050
• DeepStream Version 6.2
• TensorRT Version 8.5.3
• NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
• Issue Type( questions, new requirements, bugs) bug
What is the difference between libnvds_azure_edge_proto.so and libnvds_azure_proto.so - I’ve tried using libnvds_azure_edge_proto.so but I get the below error. libnvds_azure_proto.so seems to work…
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: Could not configure supporting library.
2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: Could not configure supporting library.2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: gstnvmsgbroker.cpp(401): legacy_gst_nvmsgbroker_start (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:
gstnvmsgbroker.cpp(401): legacy_gst_nvmsgbroker_start (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: unable to connect to broker library
unable to connect to broker library2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
2023-04-03 15:58:38.704 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:
gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: Failed to start
Failed to start2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.705 ERROR extensions/nvdsbase/nvds_scheduler.cpp@184: Failed to set GStreamer pipeline to PLAYING
2023-04-03 15:58:38.705 ERROR extensions/nvdsbase/nvds_scheduler.cpp@184: Failed to set GStreamer pipeline to PLAYING2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: Could not configure supporting library.
2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: Could not configure supporting library.2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:
2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,789ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:
2023-04-03 15:58:38.710 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:
gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvMsgBrokerBin:Cloud Message Converter and Broker/Cloud Message Converter and Broker3/GstNvMsgBroker:nvmsgbrokersinkbin-nvmsgbroker:2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]: Failed to start
Failed to start2023-04-03 13:58:38 [371,790ms] [Error] [omni.kit.app._impl] [py stderr]:
Error: Time:Mon Apr 3 15:58:38 2023 File:/home/unnik/work/deepstream/iot/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:retrieve_edge_environment_variabes Line:177 Environment IOTEDGE_AUTHSCHEME not set
Error: Time:Mon Apr 3 15:58:38 2023 File:/home/unnik/work/deepstream/iot/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:IoTHubClientCore_LL_CreateFromEnvironment Line:1186 retrieve_edge_environment_variabes failed
Error: Time:Mon Apr 3 15:58:38 2023 File:/home/unnik/work/deepstream/iot/azure-iot-sdk-c/iothub_client/src/iothub_client_core.c Func:create_iothub_instance Line:924 Failure creating iothub handle
ERROR: iotHubModuleClientHandle is NULL! connect failed
Returned, stopping playback
Deleting pipeline
2023-04-03 15:58:38.711 INFO gxf/gxe/gxe.cpp@278: Deinitializing...
2023-04-03 15:58:38.711 INFO gxf/gxe/gxe.cpp@285: Destroying context
2023-04-03 15:58:38.712 INFO gxf/gxe/gxe.cpp@291: Context destroyed.
End One.yaml
[INFO] Graph installation dir
One.yaml (7.7 KB)
Attached - My Graph Definition
Also - Can the proto be the cause of the output being in the incorrect format? See below…
Current Pipeline Output Format :
Source 1: Frame Number = 17627 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17641 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17628 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17642 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17629 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17643 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17630 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17644 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17631 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17645 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17632 Total objects = 0 [ Person:0 ]
Source 0: Frame Number = 17646 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
Source 1: Frame Number = 17633 Total objects = 0 [ Person:0 ]
Expected Format:
“version”: “4.0”,
“id”: 0,
“@timestamp”: “1970-01-01T00:00:00.000Z”,
“sensorId”: “Yard”,
“objects”: [
“1|274.667|139.412|474.667|322.941|Car”
"version": "4.0",
"id": 26,
"@timestamp": "2020-05-03T20:47:27.435Z",
"sensorId": "Yard",
"objects": [
"2|274.667|137.647|484|324.706|Car"
"version": "4.0",
"id": 27,
"@timestamp": "2020-05-03T20:47:27.483Z",
"sensorId": "Yard",
"objects": [
"2|276|137.647|486.667|326.471|Car"
"version": "4.0",
"id": 28,
"@timestamp": "2020-05-03T20:47:27.498Z",
"sensorId": "Yard",
"objects": [
"2|276|137.647|488|326.471|Car"
