I know this is probably a confusing title for a post. Let me explain:
I acquired recently a new laptop with a 3060 RTX GPU. The machine is currently able to run CUDA applications from within Windows Subsystem for Linux with no problems so far.
I created an app that would, in addition to CUDA, use OptiX (7.5) to run a kernel in the RTX cores of the machine. I can confirm 100% that the app works fine in a remote server environment, using Ubuntu 18.04. But, the app won’t work in the laptop due to OPTIX_ERROR_LIBRARY_NOT_FOUND when invoking optixInit().
I checked, and found out that libnvoptix.so.1 and libnvoptix_loader.so.1 are currently present in the /usr/lib/wsl/lib directory, along with libcuda.so.1.
As a matter of fact, I ran the app through strace, and found that libcuda.so.1 is searched in many, many directories, before finally settling for /usr/lib/wsl/lib/libcuda.so.1 . HOWEVER, the same cannot be said of libnvoptix.so.1, or the loader - the logs tell me the loader is never searched upon, and looking for libnvoptix.so.1 is tried through the same directories as libcuda.so.1 except for the /usr/lib/wsl/lib directory. It is as if the OptiX API was intentionally skipping that particular directory.
Am I missing something here? Should I be somehow telling OptiX to do a search at the full library path to find libnvoptix.so.1? Or is there something I misconfigured in my app?
(And, no, I haven’t attempted yet to create a symlink to the library - I don’t get why libcuda.so.1 is found, but libnvoptix.so.1 isn’t…)
Any help you could provide will be highly appreciated!
