Libnvrm_gpu.so: NvRmGpuLibOpen failed
hello, i used r36.3 rootfs for my jetson agx orin industrial device, but recently i execute my demo program and use cuda lib. then there is an error occurred, plz help me have a check when available, thanks!! what mean about error code 6?
Is your app compiled in the same environment or copied from other devices?
yes, the same environment(on same machine), and now it seems run normally after i reboot the device… i am confused about its stability. i have no idea what reason causes this error…
