I’m getting a build warning when trying to compile caffe after install cudnn using CMake:
runtime library [libcudnn.so.7] in /usr/lib/aarch64-linux-gnu may be hidden by files in:
/usr/local/cuda-9.0/lib64
I’m wondering if anyone has seen this type of issue before and knows how to fix it, it seems like it’s just a path configuration problem.
Here’s the full output:
nvidia@tegra-ubuntu:~/caffe/build$ cmake ..
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- system
-- thread
-- filesystem
-- chrono
-- date_time
-- atomic
-- Found GFlags: /usr/include
-- Found gflags (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libgflags.so)
-- Found Glog: /usr/include
-- Found glog (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libglog.so)
-- Found Protobuf: /usr/lib/aarch64-linux-gnu/libprotobuf.so
-- Found PROTOBUF Compiler: /usr/bin/protoc
-- Found HDF5: /usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5_hl.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libsz.so;/usr/lib/aarch64-linux-gnu/libz.so;/usr/lib/aarch64-linux-gnu/libdl.so;/usr/lib/aarch64-linux-gnu/libm.so (found version "1.8.16")
-- Found LMDB: /usr/include
-- Found lmdb (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/liblmdb.so)
-- Found LevelDB: /usr/include
-- Found LevelDB (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libleveldb.so)
-- Found Snappy: /usr/include
-- Found Snappy (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libsnappy.so)
-- CUDA detected: 9.0
-- Found cuDNN: ver. 7.1.2 found (include: /usr/local/cuda-9.0/include, library: /usr/lib/aarch64-linux-gnu/libcudnn.so)
-- Added CUDA NVCC flags for: sm_62
-- OpenCV found (/opt/ros/kinetic/share/OpenCV-3.3.1)
-- Found Atlas: /usr/include
-- Found Atlas (include: /usr/include library: /usr/lib/libatlas.so lapack: /usr/lib/liblapack.so
-- Found PythonInterp: /usr/bin/python2.7 (found suitable version "2.7.12", minimum required is "2.7")
-- Found PythonLibs: /usr/lib/aarch64-linux-gnu/libpython2.7.so (found suitable version "2.7.12", minimum required is "2.7")
-- Found NumPy: /usr/lib/python2.7/dist-packages/numpy/core/include (found suitable version "1.11.0", minimum required is "1.7.1")
-- NumPy ver. 1.11.0 found (include: /usr/lib/python2.7/dist-packages/numpy/core/include)
-- python
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.11")
-- Detected Doxygen OUTPUT_DIRECTORY: ./doxygen/
-- Found Git: /usr/bin/git (found version "2.7.4")
-- ******************* Caffe Configuration Summary *******************
-- General:
-- Version : 1.0.0
-- Git : 1.0-98-g18b09e8
-- System : Linux
-- C++ compiler : /usr/bin/c++
-- Release CXX flags : -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Debug CXX flags : -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Build type : Release
-- BUILD_SHARED_LIBS : ON
-- BUILD_python : ON
-- BUILD_matlab : OFF
-- BUILD_docs : ON
-- CPU_ONLY : OFF
-- USE_OPENCV : ON
-- USE_LEVELDB : ON
-- USE_LMDB : ON
-- USE_NCCL : OFF
-- ALLOW_LMDB_NOLOCK : OFF
-- Dependencies:
-- BLAS : Yes (Atlas)
-- Boost : Yes (ver. 1.58)
-- glog : Yes
-- gflags : Yes
-- protobuf : Yes (ver. 2.6.1)
-- lmdb : Yes (ver. 0.9.17)
-- LevelDB : Yes (ver. 1.18)
-- Snappy : Yes (ver. 1.1.3)
-- OpenCV : Yes (ver. 3.3.1)
-- CUDA : Yes (ver. 9.0)
-- NVIDIA CUDA:
-- Target GPU(s) : Auto
-- GPU arch(s) : sm_62
-- cuDNN : Yes (ver. 7.1.2)
-- Python:
-- Interpreter : /usr/bin/python2.7 (ver. 2.7.12)
-- Libraries : /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
-- NumPy : /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
-- Documentaion:
-- Doxygen : /usr/bin/doxygen (1.8.11)
-- config_file : /home/nvidia/caffe/.Doxyfile
-- Install:
-- Install path : /home/nvidia/caffe/build/install
-- Configuring done
CMake Warning (dev) in src/caffe/CMakeLists.txt:
Policy CMP0022 is not set: INTERFACE_LINK_LIBRARIES defines the link
interface. Run "cmake --help-policy CMP0022" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
Target "caffe" has an INTERFACE_LINK_LIBRARIES property which differs from
its LINK_INTERFACE_LIBRARIES properties.
INTERFACE_LINK_LIBRARIES:
caffeproto;/usr/lib/aarch64-linux-gnu/libboost_system.so;/usr/lib/aarch64-linux-gnu/libboost_thread.so;/usr/lib/aarch64-linux-gnu/libboost_filesystem.so;/usr/lib/aarch64-linux-gnu/libboost_chrono.so;/usr/lib/aarch64-linux-gnu/libboost_date_time.so;/usr/lib/aarch64-linux-gnu/libboost_atomic.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libglog.so;/usr/lib/aarch64-linux-gnu/libgflags.so;$<$<NOT:$<CONFIG:DEBUG>>:/usr/lib/aarch64-linux-gnu/libprotobuf.so>;$<$<CONFIG:DEBUG>:/usr/lib/aarch64-linux-gnu/libprotobuf.so>;-lpthread;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5_hl.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libsz.so;/usr/lib/aarch64-linux-gnu/libz.so;/usr/lib/aarch64-linux-gnu/libdl.so;/usr/lib/aarch64-linux-gnu/libm.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5_hl.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libsz.so;/usr/lib/aarch64-linux-gnu/libz.so;/usr/lib/aarch64-linux-gnu/libdl.so;/usr/lib/aarch64-linux-gnu/libm.so;/usr/lib/aarch64-linux-gnu/liblmdb.so;/usr/lib/aarch64-linux-gnu/libleveldb.so;/usr/local/cuda-9.0/lib64/libcudart.so;/usr/local/cuda-9.0/lib64/libcurand.so;/usr/local/cuda-9.0/lib64/libcublas.so;/usr/lib/aarch64-linux-gnu/libcudnn.so;opencv_core;opencv_highgui;opencv_imgproc;opencv_imgcodecs;/usr/lib/liblapack.so;/usr/lib/libcblas.so;/usr/lib/libatlas.so;/usr/lib/aarch64-linux-gnu/libboost_python.so
LINK_INTERFACE_LIBRARIES:
caffeproto;/usr/lib/aarch64-linux-gnu/libboost_system.so;/usr/lib/aarch64-linux-gnu/libboost_thread.so;/usr/lib/aarch64-linux-gnu/libboost_filesystem.so;/usr/lib/aarch64-linux-gnu/libboost_chrono.so;/usr/lib/aarch64-linux-gnu/libboost_date_time.so;/usr/lib/aarch64-linux-gnu/libboost_atomic.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libglog.so;/usr/lib/aarch64-linux-gnu/libgflags.so;/usr/lib/aarch64-linux-gnu/libprotobuf.so;-lpthread;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5_hl.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libsz.so;/usr/lib/aarch64-linux-gnu/libz.so;/usr/lib/aarch64-linux-gnu/libdl.so;/usr/lib/aarch64-linux-gnu/libm.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5_hl.so;/usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so;/usr/lib/aarch64-linux-gnu/libpthread.so;/usr/lib/aarch64-linux-gnu/libsz.so;/usr/lib/aarch64-linux-gnu/libz.so;/usr/lib/aarch64-linux-gnu/libdl.so;/usr/lib/aarch64-linux-gnu/libm.so;/usr/lib/aarch64-linux-gnu/liblmdb.so;/usr/lib/aarch64-linux-gnu/libleveldb.so;/usr/local/cuda-9.0/lib64/libcudart.so;/usr/local/cuda-9.0/lib64/libcurand.so;/usr/local/cuda-9.0/lib64/libcublas.so;/usr/lib/aarch64-linux-gnu/libcudnn.so;opencv_core;opencv_highgui;opencv_imgproc;opencv_imgcodecs;/usr/lib/liblapack.so;/usr/lib/libcblas.so;/usr/lib/libatlas.so;/usr/lib/aarch64-linux-gnu/libboost_python.so
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning at src/caffe/CMakeLists.txt:23 (add_library):
Cannot generate a safe runtime search path for target caffe because files
in some directories may conflict with libraries in implicit directories:
Some of these libraries may not be found correctly.
CMake Warning at src/caffe/test/CMakeLists.txt:29 (add_executable):
Cannot generate a safe runtime search path for target test.testbin because
files in some directories may conflict with libraries in implicit
directories:
CMake Warning at tools/CMakeLists.txt:14 (add_executable):
Cannot generate a safe runtime search path for target extract_features
because files in some directories may conflict with libraries in implicit
directories:
upgrade_net_proto_text because files in some directories may conflict with
Cannot generate a safe runtime search path for target convert_imageset
directories:
upgrade_net_proto_binary because files in some directories may conflict
Cannot generate a safe runtime search path for target compute_image_mean
directories:
Cannot generate a safe runtime search path for target caffe.bin because
directories:
upgrade_solver_proto_text because files in some directories may conflict
CMake Warning at examples/CMakeLists.txt:11 (add_executable):
convert_mnist_siamese_data because files in some directories may conflict
Cannot generate a safe runtime search path for target classification
directories:
Cannot generate a safe runtime search path for target convert_mnist_data
directories:
Cannot generate a safe runtime search path for target convert_cifar_data
directories:
CMake Warning at python/CMakeLists.txt:8 (add_library):
Cannot generate a safe runtime search path for target pycaffe because files
-- Generating done
-- Build files have been written to: /home/nvidia/caffe/build
