I tried to compile Caffe and this mistakes occurred:
root@ubuntu:/softwares_nvidia/caffe/build# cmake ..
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- system
-- thread
-- filesystem
-- chrono
-- date_time
-- atomic
-- Found gflags (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so)
-- Found glog (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so)
-- Found PROTOBUF Compiler: /usr/local/bin/protoc
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- HDF5: Using hdf5 compiler wrapper to determine CXX configuration
-- Found lmdb (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/liblmdb.so)
-- Found LevelDB (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libleveldb.so)
-- Found Snappy (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libsnappy.so)
-- CUDA detected: 10.1
-- Found cuDNN: ver. 7.5.0 found (include: /usr/local/cuda/include, library: /usr/local/cuda/lib64/libcudnn.so)
-- Added CUDA NVCC flags for: sm_70
-- OpenCV found (/usr/share/OpenCV)
-- Found Atlas (include: /usr/include, library: /usr/lib/libatlas.so)
-- NumPy ver. 1.11.0 found (include: /usr/lib/python2.7/dist-packages/numpy/core/include)
-- python
-- Found NCCL (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libnccl.so)
-- Detected Doxygen OUTPUT_DIRECTORY: ./doxygen/
-- ******************* Caffe Configuration Summary *******************
-- General:
-- Version : 0.15.14
-- Git : v0.15.14-16-g4b8d54d-dirty
-- System : Linux
-- C++ compiler : /usr/bin/c++
-- Release CXX flags : -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Debug CXX flags : -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Build type : Release
-- BUILD_SHARED_LIBS : ON
-- BUILD_python : ON
-- BUILD_matlab : OFF
-- BUILD_docs : ON
-- CPU_ONLY : OFF
-- USE_OPENCV : ON
-- USE_LEVELDB : ON
-- USE_LMDB : ON
-- ALLOW_LMDB_NOLOCK : OFF
-- Dependencies:
-- BLAS : Yes (Atlas)
-- Boost : Yes (ver. 1.58)
-- glog : Yes
-- gflags : Yes
-- protobuf : Yes (ver. 3.2.0)
-- lmdb : Yes (ver. 0.9.17)
-- LevelDB : Yes (ver. 1.18)
-- Snappy : Yes (ver. 1.1.3)
-- OpenCV : Yes (ver. 2.4.9.1)
-- CUDA : Yes (ver. 10.1)
-- NVIDIA CUDA:
-- Target GPU(s) : Auto
-- GPU arch(s) : sm_70
-- cuDNN : Yes (ver. 7.5.0)
-- NCCL : Yes
-- Python:
-- Interpreter : /usr/bin/python2.7 (ver. 2.7.12)
-- Libraries : /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.12)
-- NumPy : /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
-- Documentaion:
-- Doxygen : /usr/bin/doxygen (1.8.11)
-- config_file : /softwares_nvidia/caffe/.Doxyfile
-- Install:
-- Install path : /softwares_nvidia/caffe/build/install
-- Configuring done
CMake Warning at src/caffe/CMakeLists.txt:20 (add_library):
Cannot generate a safe runtime search path for target caffe because files
in some directories may conflict with libraries in implicit directories:
runtime library [libcublas.so] in /usr/lib/x86_64-linux-gnu may be hidden by files in:
Some of these libraries may not be found correctly.
CMake Warning at src/caffe/test/CMakeLists.txt:29 (add_executable):
Cannot generate a safe runtime search path for target test.testbin because
files in some directories may conflict with libraries in implicit
directories:
CMake Warning at tools/CMakeLists.txt:14 (add_executable):
upgrade_solver_proto_text because files in some directories may conflict
Cannot generate a safe runtime search path for target device_query because
directories:
Cannot generate a safe runtime search path for target caffe.bin because
directories:
Cannot generate a safe runtime search path for target test_net because
directories:
Cannot generate a safe runtime search path for target train_net because
directories:
Cannot generate a safe runtime search path for target compute_image_mean
because files in some directories may conflict with libraries in implicit
directories:
Cannot generate a safe runtime search path for target convert_imageset
directories:
upgrade_net_proto_binary because files in some directories may conflict
upgrade_net_proto_text because files in some directories may conflict with
Cannot generate a safe runtime search path for target extract_features
directories:
Cannot generate a safe runtime search path for target finetune_net because
directories:
Cannot generate a safe runtime search path for target net_speed_benchmark
directories:
CMake Warning at examples/CMakeLists.txt:11 (add_executable):
Cannot generate a safe runtime search path for target convert_cifar_data
directories:
Cannot generate a safe runtime search path for target convert_mnist_data
directories:
Cannot generate a safe runtime search path for target classification
directories:
convert_mnist_siamese_data because files in some directories may conflict
CMake Warning at python/CMakeLists.txt:9 (add_library):
Cannot generate a safe runtime search path for target pycaffe because files
-- Generating done
-- Build files have been written to: /softwares_nvidia/caffe/build
Can help me?
