Cannot Compile Caffe
I already install Caffe, but i tried to import module and this error ocorred:
root@ubuntu:/softwares_nvidia/caffe/build# make install
-- Boost version: 1.58.0
-- Found the following Boost libraries:
--   system
--   thread
--   filesystem
--   chrono
--   date_time
--   atomic
-- Found gflags  (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so)
-- Found glog    (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so)
-- Found PROTOBUF Compiler: /usr/local/bin/protoc
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- HDF5: Using hdf5 compiler wrapper to determine CXX configuration
-- Found lmdb    (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/liblmdb.so)
-- Found LevelDB (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libleveldb.so)
-- Found Snappy  (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libsnappy.so)
-- CUDA detected: 10.1
-- Found cuDNN: ver. 7.5.0 found (include: /usr/local/cuda/include, library: /usr/local/cuda/lib64/libcudnn.so)
-- Added CUDA NVCC flags for: sm_70
-- OpenCV found (/usr/share/OpenCV)
-- Found Atlas (include: /usr/include, library: /usr/lib/libatlas.so)
-- NumPy ver. 1.11.0 found (include: /usr/lib/python2.7/dist-packages/numpy/core/include)
--   python
-- Found NCCL (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libnccl.so)
-- Detected Doxygen OUTPUT_DIRECTORY: ./doxygen/
-- ******************* Caffe Configuration Summary *******************
-- General:
--   Version           :   0.15.14
--   Git               :   v0.15.14-16-g4b8d54d-dirty
--   System            :   Linux
--   C++ compiler      :   /usr/bin/c++
--   Release CXX flags :   -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
--   Debug CXX flags   :   -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
--   Build type        :   Release
--   BUILD_SHARED_LIBS :   ON
--   BUILD_python      :   ON
--   BUILD_matlab      :   OFF
--   BUILD_docs        :   ON
--   CPU_ONLY          :   OFF
--   USE_OPENCV        :   ON
--   USE_LEVELDB       :   ON
--   USE_LMDB          :   ON
--   ALLOW_LMDB_NOLOCK :   OFF
-- Dependencies:
--   BLAS              :   Yes (Atlas)
--   Boost             :   Yes (ver. 1.58)
--   glog              :   Yes
--   gflags            :   Yes
--   protobuf          :   Yes (ver. 3.2.0)
--   lmdb              :   Yes (ver. 0.9.17)
--   LevelDB           :   Yes (ver. 1.18)
--   Snappy            :   Yes (ver. 1.1.3)
--   OpenCV            :   Yes (ver. 2.4.9.1)
--   CUDA              :   Yes (ver. 10.1)
-- NVIDIA CUDA:
--   Target GPU(s)     :   Auto
--   GPU arch(s)       :   sm_70
--   cuDNN             :   Yes (ver. 7.5.0)
--   NCCL              :   Yes
-- Python:
--   Interpreter       :   /usr/bin/python2.7 (ver. 2.7.12)
--   Libraries         :   /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.12)
--   NumPy             :   /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
-- Documentaion:
--   Doxygen           :   /usr/bin/doxygen (1.8.11)
--   config_file       :   /softwares_nvidia/caffe/.Doxyfile
-- Install:
--   Install path      :   /softwares_nvidia/caffe/build/install
-- Configuring done
-- Generating done
-- Build files have been written to: /softwares_nvidia/caffe/build
[  2%] Built target proto
Scanning dependencies of target caffe
[  2%] Linking CXX shared library ../../lib/libcaffe-nv.so
[ 83%] Built target caffe
[ 84%] Linking CXX executable upgrade_solver_proto_text
[ 84%] Built target upgrade_solver_proto_text
[ 86%] Linking CXX executable device_query
[ 86%] Built target device_query
[ 87%] Linking CXX executable caffe
[ 87%] Built target caffe.bin
[ 89%] Linking CXX executable test_net
[ 89%] Built target test_net
[ 89%] Linking CXX executable train_net
[ 89%] Built target train_net
[ 89%] Linking CXX executable compute_image_mean
[ 90%] Built target compute_image_mean
[ 91%] Linking CXX executable convert_imageset
[ 91%] Built target convert_imageset
[ 91%] Linking CXX executable upgrade_net_proto_binary
[ 93%] Built target upgrade_net_proto_binary
[ 94%] Linking CXX executable upgrade_net_proto_text
[ 94%] Built target upgrade_net_proto_text
[ 94%] Linking CXX executable extract_features
[ 95%] Built target extract_features
[ 97%] Linking CXX executable finetune_net
[ 97%] Built target finetune_net
[ 97%] Linking CXX executable net_speed_benchmark
[ 97%] Built target net_speed_benchmark
[ 97%] Linking CXX executable cifar10/convert_cifar_data
[ 98%] Built target convert_cifar_data
[ 98%] Linking CXX executable mnist/convert_mnist_data
[ 98%] Built target convert_mnist_data
[ 98%] Linking CXX executable cpp_classification/classification
[ 98%] Built target classification
[ 98%] Linking CXX executable siamese/convert_mnist_siamese_data
[100%] Built target convert_mnist_siamese_data
[100%] Linking CXX shared library ../lib/_caffe.so
Creating symlink /softwares_nvidia/caffe/python/caffe/_caffe.so -> /softwares_nvidia/caffe/build/lib/_caffe.so
[100%] Built target pycaffe
Install the project...
-- Install configuration: "Release"
-- Installing: /softwares_nvidia/caffe/build/install/share/Caffe/CaffeConfig.cmake
-- Installing: /softwares_nvidia/caffe/build/install/share/Caffe/CaffeTargets.cmake
-- Installing: /softwares_nvidia/caffe/build/install/share/Caffe/CaffeTargets-release.cmake
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/accuracy_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/tanh_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_batch_norm_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/split_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/python_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/l1_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/pooling_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/memory_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/filter_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/relu_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/power_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/argmax_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/image_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/silence_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/multinomial_logistic_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/window_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/batch_norm_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/hinge_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_conv_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/base_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/eltwise_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/absval_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_sigmoid_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/scale_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_tanh_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/infogain_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/tile_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/im2col_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/concat_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/input_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/exp_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/crop_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/mvn_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/flatten_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/prelu_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_lrn_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/reshape_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_softmax_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/hdf5_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/hdf5_output_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/sigmoid_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/bias_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/euclidean_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/reduction_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_lcn_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/dummy_data_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_relu_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/embed_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/neuron_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/contrastive_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/softmax_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/detectnet_transform_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/sigmoid_cross_entropy_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/slice_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/deconv_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/conv_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/lrn_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/batch_reindex_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/threshold_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/log_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/dropout_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/elu_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/inner_product_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/cudnn_pooling_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/spp_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/bnll_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/base_conv_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layers/softmax_loss_layer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/net.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/data_transformer.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/blob.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/solver_factory.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/test
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/test/test_caffe_main.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/test/test_gradient_check_util.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/sgd_solvers.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/common.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/layer_factory.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/rng.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/hdf5.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/format.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/detectnet_coverage.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/insert_splits.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/upgrade_proto.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/gpu_memory.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/device_alternate.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/io.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/nccl.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/signal_handler.h
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/blocking_queue.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/im2col.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/gpu_util.cuh
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/db_lmdb.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/cudnn.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/db_leveldb.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/thread_pool.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/db.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/mkl_alternate.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/benchmark.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/util/math_functions.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/internal_thread.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/solver.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/data_reader.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/parallel.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/filler.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/caffe.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/syncedmem.hpp
-- Installing: /softwares_nvidia/caffe/build/install/include/caffe/proto/caffe.pb.h
-- Installing: /softwares_nvidia/caffe/build/install/lib/libcaffe-nv.so.0.15.14
-- Set runtime path of "/softwares_nvidia/caffe/build/install/lib/libcaffe-nv.so.0.15.14" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/lib/libproto.a
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/proto/caffe_pb2.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/proto/__init__.py
-- Installing: /softwares_nvidia/caffe/build/install/bin/caffe
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/caffe" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/compute_image_mean
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/compute_image_mean" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/convert_imageset
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/convert_imageset" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/device_query
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/device_query" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/extract_features
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/extract_features" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/finetune_net
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/finetune_net" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/net_speed_benchmark
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/net_speed_benchmark" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/test_net
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/test_net" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/train_net
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/train_net" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/upgrade_net_proto_binary
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/upgrade_net_proto_binary" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/upgrade_net_proto_text
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/upgrade_net_proto_text" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/upgrade_solver_proto_text
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/upgrade_solver_proto_text" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/convert_cifar_data
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/convert_cifar_data" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/classification
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/classification" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/convert_mnist_data
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/convert_mnist_data" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/bin/convert_mnist_siamese_data
-- Set runtime path of "/softwares_nvidia/caffe/build/install/bin/convert_mnist_siamese_data" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
-- Installing: /softwares_nvidia/caffe/build/install/python/classify.py
-- Installing: /softwares_nvidia/caffe/build/install/python/detect.py
-- Installing: /softwares_nvidia/caffe/build/install/python/draw_net.py
-- Installing: /softwares_nvidia/caffe/build/install/python/requirements.txt
-- Up-to-date: /softwares_nvidia/caffe/build/install/python/caffe
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/draw.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/coord_map.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers/__init__.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers/detectnet
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers/detectnet/clustering.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers/detectnet/__init__.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/layers/detectnet/mean_ap.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/classifier.py
-- Up-to-date: /softwares_nvidia/caffe/build/install/python/caffe/proto
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/__init__.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/net_spec.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/imagenet
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/imagenet/ilsvrc_2012_mean.npy
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/io.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/pycaffe.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/detector.py
-- Installing: /softwares_nvidia/caffe/build/install/python/caffe/_caffe.so
-- Set runtime path of "/softwares_nvidia/caffe/build/install/python/caffe/_caffe.so" to "/softwares_nvidia/caffe/build/install/lib:/usr/local/lib:/usr/lib/x86_64-linux-gnu/hdf5/serial:/usr/local/cuda/lib64"
root@ubuntu:/softwares_nvidia/caffe/build# python
Python 2.7.12 (default, Nov 12 2018, 14:36:49)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import caffe
  File "<stdin>", line 1, in <module>
ImportError: No module named caffe
I did not understand, the compilation was done successfully, but the module does not matter?
Can help me please?
Hi.
Did you export your caffe path to your PYTHONPATH?
I added the line below in my .bashrc .
export PYTHONPATH=/usr/src/caffe/python/:$PYTHONPATH
Of course you gonna have to edit the path your caffe location.
