I installed LibTorch to my Jetson AGX Xavier (aarch64) and I’m getting library not found
errors.
I downloaded pytorch by git clone
from the official GitHub. Link here GitHub - pytorch/pytorch: Tensors and Dynamic neural networks in Python with strong GPU acceleration
I executed ‘python3 /tools/build_libtorch.py’ from the root pytorch dir to install Libtorch.
I’m trying to build the example script from the official PyTorch page here.
This is the error I get now when I run cmake -DCMAKE_PREFIX_PATH=/home/jet/pytorch/ …
$ cmake -DCMAKE_PREFIX_PATH=/home/jet/pytorch/ ..
-- The C compiler identification is Clang 6.0.0
-- The CXX compiler identification is Clang 6.0.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/lib/ccache/clang - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/lib/ccache/clang++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Warning at /home/jet/pytorch/torch/share/cmake/Torch/TorchConfig.cmake:22 (message):
static library onnx_LIBRARY-NOTFOUND not found.
Call Stack (most recent call first):
/home/jet/pytorch/torch/share/cmake/Torch/TorchConfig.cmake:104 (append_torchlib_if_found)
CMakeLists.txt:4 (find_package)
static library foxi_loader_LIBRARY-NOTFOUND not found.
/home/jet/pytorch/torch/share/cmake/Torch/TorchConfig.cmake:106 (append_torchlib_if_found)
static library fmt_LIBRARY-NOTFOUND not found.
static library eigen_blas_LIBRARY-NOTFOUND not found.
/home/jet/pytorch/torch/share/cmake/Torch/TorchConfig.cmake:113 (append_torchlib_if_found)
static library asmjit_LIBRARY-NOTFOUND not found.
/home/jet/pytorch/torch/share/cmake/Torch/TorchConfig.cmake:123 (append_torchlib_if_found)
-- Found Torch: /home/jet/pytorch/torch/lib/libtorch.a
-- Configuring done
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
-Wl,-force_load,/home/jet/pytorch/torch/lib/libtorch.a;-Wl,-force_load,/home/jet/pytorch/torch/lib/libtorch_cpu.a;-Wl,-force_load,/home/jet/pytorch/torch/lib/libtorch_cuda.a;-Wl,-force_load,/home/jet/pytorch/torch/lib/libc10_cuda.a;/home/jet/pytorch/torch/lib/libc10.a;/home/jet/pytorch/torch/lib/libcaffe2_protos.a;/home/jet/pytorch/torch/lib/libprotobuf-lite.a;/home/jet/pytorch/torch/lib/libprotobuf.a;/home/jet/pytorch/torch/lib/libprotoc.a;/usr/lib/aarch64-linux-gnu/libonnx_proto.a;/home/jet/pytorch/torch/lib/libclog.a;/home/jet/pytorch/torch/lib/libcpuinfo.a;/home/jet/pytorch/torch/lib/libsleef.a;/home/jet/pytorch/torch/lib/libkineto.a;LIBNVTOOLSEXT
linked by target "example-app" in directory /home/jet/example-app
-- Generating done
CMake Generate step failed. Build files cannot be regenerated correctly. ```
My Linux Version
4.9.253-tegra #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021 aarch64 aarch64 aarch64 GNU/Linux
My CUDA version is 10.2
