I’m using opencv python to do image processing. I want to use threading for receive frames from 4 cameras and process them. I also want to limit fps while running(for example 10 fps) to reduce gpu usage. Is there anyway to do this? Thanks for your attention.
Related topics
Topic | Replies | Views | Activity | |
Use NvidiaOpticalFlow in Opencv-python with multiprocessing | 0 | 656 | June 9, 2021 | |
Speed up python USB camera read in python without opencv | 3 | 2162 | May 18, 2022 | |
How to access maximum frame rate in OpenCV Python for NVIDIA Jetson platforms cameras | 2 | 556 | December 8, 2021 | |
Performance analysis timing | 2 | 927 | March 18, 2015 | |
Frame rate cap | 2 | 790 | June 14, 2022 | |
FPS issue with Jetson Xavier NX for deep learning | 4 | 339 | March 27, 2024 | |
Get Viewport FPS in python | 3 | 71 | July 23, 2024 | |
Low fps | 0 | 475 | November 22, 2019 | |
Low FPS on Higher resolutions when using Raspberry pi HQ camera, high cpu usage and low gpu usage | 4 | 459 | February 1, 2024 | |
Image threshold with Nvidia VPI | 2 | 507 | May 31, 2023 |
