Recently I have been trying to install nvidia graphics drivers but I guess with little to no effect.
When I use nvidia-smi
The result I get is NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running
The data file from my nvidia-bug-report.log.tz should be attached in this post data (531.6 KB)
ii libnvidia-cfg1-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-515 515.65.01-0ubuntu0.20.04.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-390:i386 390.154-0ubuntu0.20.04.1 i386 NVIDIA libcompute package
ii libnvidia-compute-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:i386 515.65.01-0ubuntu0.20.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-515:i386 515.65.01-0ubuntu0.20.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-515:i386 515.65.01-0ubuntu0.20.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-515:i386 515.65.01-0ubuntu0.20.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-515:amd64 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-515:i386 515.65.01-0ubuntu0.20.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii linux-modules-nvidia-515-5.15.0-46-generic 5.15.0-46.49~20.04.1 amd64 Linux kernel nvidia modules for version 5.15.0-46
ii linux-modules-nvidia-515-generic-hwe-20.04 5.15.0-46.49~20.04.1 amd64 Extra drivers for nvidia-515 for the generic-hwe-20.04 flavour
ii linux-objects-nvidia-515-5.15.0-46-generic 5.15.0-46.49~20.04.1 amd64 Linux kernel nvidia modules for version 5.15.0-46 (objects)
ii linux-signatures-nvidia-5.15.0-46-generic 5.15.0-46.49~20.04.1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-46-generic
ii nvidia-compute-utils-515 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA compute utilities
ii nvidia-driver-515 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-515 515.65.01-0ubuntu0.20.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-515 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.16~0.20.04.2 all Tools to enable NVIDIA's Prime
ii nvidia-settings 470.57.01-0ubuntu0.20.04.3 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-515 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-515 515.65.01-0ubuntu0.20.04.1 amd64 NVIDIA binary Xorg driver
You have precompiled, signed nvidia modules for the standard kernel (5.15.0-46) installed but are running an oem kernel (5.14.0-1048-oem).
Youâll either have to switch to the standard kernel in grub or install the dkms modules instead.
So I installed dkms modules and I switched to the standard kernel (5.15.0-46) in the grub menu, it seemed to work the best, since when I reach the login screen, it also shows on the second monitor. The problem is that when I log into my account, my computer freezes and it disconnects from the monitor
Iâm not sure whether or not I did it correctly, since I have never set a kernel parameter, but I edited /ect/default/grub file and added the parameter you mentioned, at the end of the file.
I restarted my computer and in the GRUB menu, I chose advaced options, hovered the standard 5.15.0-46 kernel and pressed âeâ. Then, I found a line that started with âlinuxâ and after the words âquiet splashâ I wrote nvidia-drm.modeset=1 (remembered to add space afterâsplashâ) and pressed F10.
Iâm writing in so much detail since Iâm not sure if I did everything correctly because unfortunately, I didnât see any change.
Please remove it from the end of /ect/default/grub and put it inside
GRUB_CMDLINE_DEFAULT=âquiet splash nvidia-drm.modeset=1â
afterwards, run
sudo update-grub
In the login screen, please check what session is selected, should be gnome on Xorg.
