Linux Graphics Cards Installation
We are trying to install nvidia-driver to access physical machines GPU. We are using Ubuntu as virtual machine (downloaded via Oracle Virtualbox). Our first attempt was to run YOLO for object detection, but we have encountered several errors , for example , OS doesn’t seem to use physicals machine GPU and further being unable to install drivers for the virtual machine
Is this problem related to virtual machine or something about the driver support? Also one more question, could it be the reason that Virtualbox doesn’t support pass through?
this.
In case you only need cuda and your host OS is Windows, I guess you’re better off using WSL https://docs.nvidia.com/cuda/wsl-user-guide/index.html
