Release highlights since 358.16:
- The OpenGL Vendor-Neutral Driver (GLVND) infrastructure is now included and supported by the NVIDIA GLX and OpenGL drivers. This should not cause any visible changes in behavior for end users, but some internal driver component libraries have been renamed and/or moved as a result. These changes may affect scripts that rely on the presence of NVIDIA OpenGL driver components other than those specified in the Linux OpenGL ABI version 1.0, maintainers of alternative NVIDIA driver installation packages, and applications which rely on the presence of any non- OpenGL/GLX symbols in the libGL.so.1 library and its dependencies in any way.
Please see:
<a target='_blank' rel='noopener noreferrer' href='https://github.com/NVIDIA/libglvnd'>https://github.com/NVIDIA/libglvnd</a>For more information on the GLVND project.
The Linux OpenGL ABI version 1.0 specification is available at:
<a target='_blank' rel='noopener noreferrer' href='https://www.opengl.org/registry/ABI'>https://www.opengl.org/registry/ABI</a> - Updated nvidia-installer to run ldconfig(8) and depmod(8) after uninstalling an existing driver, instead of only running these two commands when installing a new driver.
- Removed the VDPAU wrapper and trace libraries libvdpau.so.1 and libvdpau_trace.so.1 from the driver package. These libraries may be available via your distribution's package management system, or can be compiled from the sources available at:
<a target='_blank' rel='noopener noreferrer' href='http://people.freedesktop.org/~aplattner/vdpau/'>http://people.freedesktop.org/~aplattner/vdpau/</a>Please see
<a target='_blank' rel='noopener noreferrer' href='http://freedesktop.org/wiki/Software/VDPAU/'>http://freedesktop.org/wiki/Software/VDPAU/</a>for more information.
- Fixed a bug in the EGL driver where a mutex was unlocked more than once. This triggers undefined behavior, and in particular, if lock elision is enabled in glibc, may result in a segmentation fault.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
