Release highlights since 367.44:
- Added support for the following GPUs:
- Quadro P6000
- Tesla P40
- Quadro P5000
- Fixed a bug that could prevent systems with GPUs configured in SLI from resuming correctly from ACPI S3/S4 sleep/hibernate states.
- Added support for NVIDIA 3D Vision 2 Stereo on Linux. This IR emitter can be used with stereo mode "10" set in the X configuration file.
- Fixed a bug in nvidia-persistenced that caused it to incorrectly delete the PID file if a second instance of the daemon is started.
- Fixed a bug that could cause quad-buffered stereo applications to crash when disabling displays.
- Updated the behavior of the nvidia-settings control panel upon closing the control panel window to be consistent with clicking the control panel's "Quit" button.
- Added support for the screen_info.ext_lfb_base field, on kernels that have it, in order to properly handle UEFI framebuffer consoles with physical addresses above 4GB.
- Fixed a bug that allowed nvidia-installer to attempt loading kernel modules that were built against non-running kernels.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
