Release highlights since 418.56:
- Added support for the following GPUs:
- GeForce GTX 1650
- GeForce GTX 1650 with Max-Q Design
- GeForce GTX 1660 Ti with Max-Q Design
- Fixed a bug that could cause the display to be driven at a low resolution when configuring PRIME display offloading with `nvidia-xconfig --prime`.
- Added HEVC YUV 4:4:4 decode support to the NVIDIA VDPAU driver.
- Added the new per-decoder profile capability bit VDP_DECODER_PROFILE_SUPPORTED_CHROMA_TYPES to the NVIDIA VDPAU driver.
- Added new VdpYCbCrFormats VDP_YCBCR_FORMAT_Y_UV_444 and VDP_YCBCR_FORMAT_Y_U_V_444 for accessing YUV 4:4:4 surfaces via VdpVideoSurfaceGetBitsYCbCr() and VdpVideoSurfacePutBitsYCbCr() in the NVIDIA VDPAU driver.
- Added support for creation of YUV 4:4:4 video surfaces in the NVIDIA VDPAU driver.
- Raised the minimum supported X.Org xserver version to 1.7 (video driver ABI version 6).
- Updated the NVIDIA VDPAU driver to support allocating VDPAU video surfaces with explicit field or frame picture structure.
- Added support for the GL_NV_vdpau_interop2 OpenGL extension, which allows VDPAU/OpenGL surface sharing with explicit field or frame picture structure. Picture structure selection by applications can avoid the need for implicit surface structure conversion by the OpenGL implementation.
- Updated nvidia-installer for better compatibility with ncurses when libncurses.so.6 exposes the ncurses reentrant ABI, such as on openSUSE Leap 15 and SUSE Linux Enterprise 15.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
