Llama-2-finetune clone project failed
failed to build the container …
both ngc and github credentials are generated
Hi - I believe this is because the Project container is further gated in a separate EA program. It is “GA” but not yet fully public. This isn’t sufficiently documented in the Readme and we will change that.
If you join the NeMo Frameworks program, here, you should be granted immediate access and it will work.
Let me know how it goes.
Raed,
Suggested fix for your issue was to join the NeMo GA program here: Apply for NeMo Framework | NVIDIA Developer
Did that fix the problem?
tyler
I am having the same issue. I’ve joined the NeMo GA program, and can download the containers through the browser, but am getting a similar message, image attached.
Hi Mike,
Thank you for posting. My guess is you don’t have an NGC API key setup. That is required to access the container.
Two questions:
  1. Did you set up your NGC credential in workbench?
  2. When you run the following in the command line, what do you see?
    $ nvwb list credentials
Note, if you are on Windows then you need to be in the WSL2 terminal associated with the distro NVIDIA-Workbench to run this command.
If you don’t have an NGC API key, go here to login or create an account.
After you’ve logged in, go to the upper right corner and click on your user icon, and then go to the Setup option.
In the setup option, click the “Get API Key” button on the “Generate API Key” card.
Then, click “Generate API Key” and copy the result where it prints.
Finally, go back to the terminal and run the following command: $ nvwb create credential ngc <api_key>
After that, try to clone the Project again.
Ah yes, you are correct, I forgot to add that credential. I’ve added as you suggested and it’s off and running now.
thanks
Amazing!
