I am trying to log into nvcr.io but get the follwoing errors:
$ ./ngc registry image pull nvcr.io/nvidia/pytorch:21.05-py3
Logging in to https://nvcr.io... login failed.
500 Server Error for http+docker://localhost/v1.41/auth: Internal Server Error ("login attempt to https://nvcr.io/v2/ failed with status: 502 Bad Gateway")
And with docker
$ docker login nvcr.io
Username: $oauthtoken
Password:
Error response from daemon: login attempt to https://nvcr.io/v2/ failed with status: 502 Bad Gateway
I am not using any proxy or do I have any problems pulling other images with docker.
Anybody else having issues? Any idea how to resolve this?
I’m having the same issue. Might be on their side.
I’m having the same.
Was trying from different machines with different internet providers and over VPNs - every time got the same result (error 502),
Yep, same here. Started happening last night
This issue has now been resolved. Appreciate your patience! Please feel free to write back to us if you continue facing any further difficulties connecting.
I have been hitting this issue on and off, now it seems to be on for the last two weeks, I could not even start the offline gpu operator download as I do not have access to the images, could not pull, could not login to nvcr.io
