Problem description: A month ago I had my CPU as a OpenCL device, I haven’t updated anything since then, now my oclDeviceQuery doesn’t see my CPU as a valid device, when I enter …_CPU as a parameter to clCreateContextFromType it doesn’t recognise my CPU as a valid device.
Here is my oclDeviceQuery.exe output.
oclDeviceQuery.exe Starting…
OpenCL SW Info:
CL_PLATFORM_NAME: NVIDIA CUDA
CL_PLATFORM_VERSION: OpenCL 1.0 CUDA 3.2.1
OpenCL SDK Revision: 7027912
OpenCL Device Info:
1 devices found supporting OpenCL:
Device GeForce GTX 460
CL_DEVICE_NAME: GeForce GTX 460
CL_DEVICE_VENDOR: NVIDIA Corporation
CL_DRIVER_VERSION: 260.19.29
CL_DEVICE_VERSION: OpenCL 1.0 CUDA
CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
CL_DEVICE_MAX_COMPUTE_UNITS: 7
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 1024 / 1024 / 64
CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
CL_DEVICE_MAX_CLOCK_FREQUENCY: 1430 MHz
CL_DEVICE_ADDRESS_BITS: 32
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 255 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 1023 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: local
CL_DEVICE_LOCAL_MEM_SIZE: 48 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
CL_DEVICE_SINGLE_FP_CONFIG: denorms INF-quietNaNs round-to-nearest round-to-zero round-to-inf fma
CL_DEVICE_IMAGE 2D_MAX_WIDTH 4096
2D_MAX_HEIGHT 32768
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
CL_DEVICE_EXTENSIONS: cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
CL_DEVICE_COMPUTE_CAPABILITY_NV: 2.1
NUMBER OF MULTIPROCESSORS: 7
NUMBER OF CUDA CORES: 336
CL_DEVICE_REGISTERS_PER_BLOCK_NV: 32768
CL_DEVICE_WARP_SIZE_NV: 32
CL_DEVICE_GPU_OVERLAP_NV: CL_TRUE
CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV: CL_TRUE
CL_DEVICE_INTEGRATED_MEMORY_NV: CL_FALSE
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 1, SHORT 1, INT 1, LONG 1, FLOAT 1, DOUBLE 1
2D Image Formats Supported (71)
Channel Order Channel Type
1 CL_R CL_FLOAT
2 CL_R CL_HALF_FLOAT
3 CL_R CL_UNORM_INT8
4 CL_R CL_UNORM_INT16
5 CL_R CL_SNORM_INT16
6 CL_R CL_SIGNED_INT8
7 CL_R CL_SIGNED_INT16
8 CL_R CL_SIGNED_INT32
9 CL_R CL_UNSIGNED_INT8
10 CL_R CL_UNSIGNED_INT16
11 CL_R CL_UNSIGNED_INT32
12 CL_A CL_FLOAT
13 CL_A CL_HALF_FLOAT
14 CL_A CL_UNORM_INT8
15 CL_A CL_UNORM_INT16
16 CL_A CL_SNORM_INT16
17 CL_A CL_SIGNED_INT8
18 CL_A CL_SIGNED_INT16
19 CL_A CL_SIGNED_INT32
20 CL_A CL_UNSIGNED_INT8
21 CL_A CL_UNSIGNED_INT16
22 CL_A CL_UNSIGNED_INT32
23 CL_RG CL_FLOAT
24 CL_RG CL_HALF_FLOAT
25 CL_RG CL_UNORM_INT8
26 CL_RG CL_UNORM_INT16
27 CL_RG CL_SNORM_INT16
28 CL_RG CL_SIGNED_INT8
29 CL_RG CL_SIGNED_INT16
30 CL_RG CL_SIGNED_INT32
31 CL_RG CL_UNSIGNED_INT8
32 CL_RG CL_UNSIGNED_INT16
33 CL_RG CL_UNSIGNED_INT32
34 CL_RA CL_FLOAT
35 CL_RA CL_HALF_FLOAT
36 CL_RA CL_UNORM_INT8
37 CL_RA CL_UNORM_INT16
38 CL_RA CL_SNORM_INT16
39 CL_RA CL_SIGNED_INT8
40 CL_RA CL_SIGNED_INT16
41 CL_RA CL_SIGNED_INT32
42 CL_RA CL_UNSIGNED_INT8
43 CL_RA CL_UNSIGNED_INT16
44 CL_RA CL_UNSIGNED_INT32
45 CL_RGBA CL_FLOAT
46 CL_RGBA CL_HALF_FLOAT
47 CL_RGBA CL_UNORM_INT8
48 CL_RGBA CL_UNORM_INT16
49 CL_RGBA CL_SNORM_INT16
50 CL_RGBA CL_SIGNED_INT8
51 CL_RGBA CL_SIGNED_INT16
52 CL_RGBA CL_SIGNED_INT32
53 CL_RGBA CL_UNSIGNED_INT8
54 CL_RGBA CL_UNSIGNED_INT16
55 CL_RGBA CL_UNSIGNED_INT32
56 CL_BGRA CL_UNORM_INT8
57 CL_BGRA CL_SIGNED_INT8
58 CL_BGRA CL_UNSIGNED_INT8
59 CL_ARGB CL_UNORM_INT8
60 CL_ARGB CL_SIGNED_INT8
61 CL_ARGB CL_UNSIGNED_INT8
62 CL_INTENSITY CL_FLOAT
63 CL_INTENSITY CL_HALF_FLOAT
64 CL_INTENSITY CL_UNORM_INT8
65 CL_INTENSITY CL_UNORM_INT16
66 CL_INTENSITY CL_SNORM_INT16
67 CL_LUMINANCE CL_FLOAT
68 CL_LUMINANCE CL_HALF_FLOAT
69 CL_LUMINANCE CL_UNORM_INT8
70 CL_LUMINANCE CL_UNORM_INT16
71 CL_LUMINANCE CL_SNORM_INT16
3D Image Formats Supported (71)
1 CL_R CL_FLOAT
12 CL_A CL_FLOAT
23 CL_RG CL_FLOAT
34 CL_RA CL_FLOAT
45 CL_RGBA CL_FLOAT
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.0 CUDA 3.2.1, SDK Revision = 7027912, NumDevs = 1, Device = GeForce GTX 460
System Info:
Local Time/Date = 10:31:26, 04/29/2011
CPU Name: AMD Phenom™ II X6 1055T Processor
of CPU processors: 6
Linux version 2.6.35-24-generic (buildd@yellow) (gcc version 4.4.5 (Ubuntu/Linaro 4.4.4-14ubuntu5) )
What might be the problem any ideas?
