Hello friends, I was running last long lived drivers (375.66) and everything was working fine. Few days ago I made an update to new long lived drivers branch (384.59) and started to encounter issues with OpenCL acceleration. For example when using Daktable “Use OpenCL flag” in settings is greyed out. This setting was working with previous drivers. So I tried running darktable with debug opencl command (darktable -d opencl) and it showed this error:
[opencl_init] opencl related configuration options:
[opencl_init]
[opencl_init] opencl: 1
[opencl_init] opencl_library: ‘’
[opencl_init] opencl_memory_requirement: 768
[opencl_init] opencl_memory_headroom: 300
[opencl_init] opencl_device_priority: ‘/!0,//’
[opencl_init] opencl_size_roundup: 16
[opencl_init] opencl_async_pixelpipe: 0
[opencl_init] opencl_synch_cache: 0
[opencl_init] opencl_number_event_handles: 25
[opencl_init] opencl_micro_nap: 1000
[opencl_init] opencl_use_pinned_memory: 0
[opencl_init] opencl_use_cpu_devices: 0
[opencl_init] opencl_avoid_atomics: 0
[opencl_init] opencl_omit_whitebalance: 0
[opencl_init]
[opencl_init] found opencl runtime library ‘libOpenCL’
[opencl_init] opencl library ‘libOpenCL’ found on your system and loaded
[opencl_init] found 2 platforms
[opencl_init] found 3 devices
[opencl_init] device 0 GeForce GTX 960M' has sm_20 support. [opencl_init] device 0 GeForce GTX 960M’ supports image sizes of 16384 x 16384
[opencl_init] device 0 `GeForce GTX 960M’ allows GPU memory allocations of up to 1011MB
[opencl_init] device 0: GeForce GTX 960M
GLOBAL_MEM_SIZE: 4044MB
MAX_WORK_GROUP_SIZE: 1024
MAX_WORK_ITEM_DIMENSIONS: 3
MAX_WORK_ITEM_SIZES: [ 1024 1024 64 ]
DRIVER_VERSION: 384.59
DEVICE_VERSION: OpenCL 1.2 CUDA
[opencl_init] could not create context for device 0: 221
[opencl_init] FINALLY: opencl is NOT AVAILABLE on this system.
[opencl_init] initial status of opencl enabled flag is OFF.
Then I tried running oclDeviceQuery and it shows this error:
[oclDeviceQuery] starting…
./oclDeviceQuery Starting…
OpenCL SW Info:
CL_PLATFORM_NAME: NVIDIA CUDA
CL_PLATFORM_VERSION: OpenCL 1.2 CUDA 9.0.130
OpenCL SDK Revision: 7027912
OpenCL Device Info:
1 devices found supporting OpenCL:
Error 221 in clCreateContext call !!!
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.2 CUDA 9.0.130, SDK Revision = 7027912, NumDevs = 1
Linux version 3.10.0-514.26.2.el7.x86_64 (builder@kbuilder.dev.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-11) (GCC) ) #1 SMP Tue Jul 4 15:04:05 UTC 2017
[oclDeviceQuery] test results…
FAILED
exiting in 3 seconds: 3…2…1…done!
I tried to downgrade kmod-nvidia (to previous one - 375.66) and got these results:
darktable -d opencl:
[opencl_init] device 0 GeForce GTX 960M' allows GPU memory allocations of up to 1011MB [opencl_init] device 0: GeForce GTX 960M GLOBAL_MEM_SIZE: 4044MB MAX_WORK_GROUP_SIZE: 1024 MAX_WORK_ITEM_DIMENSIONS: 3 MAX_WORK_ITEM_SIZES: [ 1024 1024 64 ] DRIVER_VERSION: 375.66 DEVICE_VERSION: OpenCL 1.2 CUDA ... [opencl_init] kernel loading time: 0.0044 [opencl_init] discarding CPU device 2 Intel(R) Core™ i7-6700HQ CPU @ 2.60GHz’.
[opencl_init] OpenCL successfully initialized.
[opencl_init] here are the internal numbers and names of OpenCL devices available to darktable:
[opencl_init] 0 ‘GeForce GTX 960M’
[opencl_init] 1 ‘Intel(R) HD Graphics’
[opencl_init] these are your device priorities:
[opencl_init] image preview export thumbnail
[opencl_init] 0 1 0 0
[opencl_init] 1 -1 1 1
[opencl_init] FINALLY: opencl is AVAILABLE on this system.
[opencl_init] initial status of opencl enabled flag is ON.
Also oclDeviceQuery runs fine with older drivers:
OpenCL SW Info:
CL_PLATFORM_VERSION: OpenCL 1.2 CUDA 8.0.0
OpenCL Device Info:
Device GeForce GTX 960M
CL_DEVICE_NAME: GeForce GTX 960M
CL_DEVICE_VENDOR: NVIDIA Corporation
CL_DRIVER_VERSION: 375.66
CL_DEVICE_VERSION: OpenCL 1.2 CUDA
CL_DEVICE_OPENCL_C_VERSION: OpenCL C 1.2
CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
CL_DEVICE_MAX_COMPUTE_UNITS: 5
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 1024 / 1024 / 64
CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
CL_DEVICE_MAX_CLOCK_FREQUENCY: 1176 MHz
CL_DEVICE_ADDRESS_BITS: 64
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 1011 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 4044 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: local
CL_DEVICE_LOCAL_MEM_SIZE: 48 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 256
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 16
CL_DEVICE_SINGLE_FP_CONFIG: denorms INF-quietNaNs round-to-nearest round-to-zero round-to-inf fma
CL_DEVICE_IMAGE 2D_MAX_WIDTH 16384
2D_MAX_HEIGHT 16384
3D_MAX_WIDTH 4096
3D_MAX_HEIGHT 4096
3D_MAX_DEPTH 4096
CL_DEVICE_EXTENSIONS: cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_copy_opts
CL_DEVICE_COMPUTE_CAPABILITY_NV: 5.0
NUMBER OF MULTIPROCESSORS: 5
MapSMtoCores SM 5.0 is undefined (please update to the latest SDK)!
NUMBER OF CUDA CORES: 4294967291
CL_DEVICE_REGISTERS_PER_BLOCK_NV: 65536
CL_DEVICE_WARP_SIZE_NV: 32
CL_DEVICE_GPU_OVERLAP_NV: CL_TRUE
CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV: CL_TRUE
CL_DEVICE_INTEGRATED_MEMORY_NV: CL_FALSE
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 1, SHORT 1, INT 1, LONG 1, FLOAT 1, DOUBLE 1
2D Image Formats Supported (75)
Channel Order Channel Type
1 CL_R CL_FLOAT
2 CL_R CL_HALF_FLOAT
3 CL_R CL_UNORM_INT8
4 CL_R CL_UNORM_INT16
5 CL_R CL_SNORM_INT16
6 CL_R CL_SIGNED_INT8
7 CL_R CL_SIGNED_INT16
8 CL_R CL_SIGNED_INT32
9 CL_R CL_UNSIGNED_INT8
10 CL_R CL_UNSIGNED_INT16
11 CL_R CL_UNSIGNED_INT32
12 CL_A CL_FLOAT
13 CL_A CL_HALF_FLOAT
14 CL_A CL_UNORM_INT8
15 CL_A CL_UNORM_INT16
16 CL_A CL_SNORM_INT16
17 CL_A CL_SIGNED_INT8
18 CL_A CL_SIGNED_INT16
19 CL_A CL_SIGNED_INT32
20 CL_A CL_UNSIGNED_INT8
21 CL_A CL_UNSIGNED_INT16
22 CL_A CL_UNSIGNED_INT32
23 CL_RG CL_FLOAT
24 CL_RG CL_HALF_FLOAT
25 CL_RG CL_UNORM_INT8
26 CL_RG CL_UNORM_INT16
27 CL_RG CL_SNORM_INT16
28 CL_RG CL_SIGNED_INT8
29 CL_RG CL_SIGNED_INT16
30 CL_RG CL_SIGNED_INT32
31 CL_RG CL_UNSIGNED_INT8
32 CL_RG CL_UNSIGNED_INT16
33 CL_RG CL_UNSIGNED_INT32
34 CL_RA CL_FLOAT
35 CL_RA CL_HALF_FLOAT
36 CL_RA CL_UNORM_INT8
37 CL_RA CL_UNORM_INT16
38 CL_RA CL_SNORM_INT16
39 CL_RA CL_SIGNED_INT8
40 CL_RA CL_SIGNED_INT16
41 CL_RA CL_SIGNED_INT32
42 CL_RA CL_UNSIGNED_INT8
43 CL_RA CL_UNSIGNED_INT16
44 CL_RA CL_UNSIGNED_INT32
45 CL_RGBA CL_FLOAT
46 CL_RGBA CL_HALF_FLOAT
47 CL_RGBA CL_UNORM_INT8
48 CL_RGBA CL_UNORM_INT16
49 CL_RGBA CL_SNORM_INT16
50 CL_RGBA CL_SIGNED_INT8
51 CL_RGBA CL_SIGNED_INT16
52 CL_RGBA CL_SIGNED_INT32
53 CL_RGBA CL_UNSIGNED_INT8
54 CL_RGBA CL_UNSIGNED_INT16
55 CL_RGBA CL_UNSIGNED_INT32
56 CL_BGRA CL_UNORM_INT8
57 CL_BGRA CL_SIGNED_INT8
58 CL_BGRA CL_UNSIGNED_INT8
59 CL_ARGB CL_UNORM_INT8
60 CL_ARGB CL_SIGNED_INT8
61 CL_ARGB CL_UNSIGNED_INT8
62 CL_INTENSITY CL_FLOAT
63 CL_INTENSITY CL_HALF_FLOAT
64 CL_INTENSITY CL_UNORM_INT8
65 CL_INTENSITY CL_UNORM_INT16
66 CL_INTENSITY CL_SNORM_INT16
67 CL_LUMINANCE CL_FLOAT
68 CL_LUMINANCE CL_HALF_FLOAT
69 CL_LUMINANCE CL_UNORM_INT8
70 CL_LUMINANCE CL_UNORM_INT16
71 CL_LUMINANCE CL_SNORM_INT16
72 CL_BGRA CL_SNORM_INT8
73 CL_BGRA CL_SNORM_INT16
74 CL_ARGB CL_SNORM_INT8
75 CL_ARGB CL_SNORM_INT16
3D Image Formats Supported (75)
1 CL_R CL_FLOAT
12 CL_A CL_FLOAT
23 CL_RG CL_FLOAT
34 CL_RA CL_FLOAT
45 CL_RGBA CL_FLOAT
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.2 CUDA 8.0.0, SDK Revision = 7027912, NumDevs = 1, Device = GeForce GTX 960M
PASSED
I am running Enterprise Linux 7.3 with nvidia drivers packed from elrepo (I am 99% positive elrepo isnt source of this issue since all the drivers before were running perfectly fine and they did not change anything in last package). I just want to ask if anybody else encountered this behaviour with new drivers and if yes how can we solve it. I cant find anything related to this issue on the internet. I also tried running the softwares with sudo and got the same error. If you need any more information or testing please let me know and I will be happy to provide it.
P.S.: in both cases I had opencl-filesystem opencl-headers and ocl-icd installed
Have a nice day :)
