Low PCIe read speed
An X86 PC acts as the PCIe Root Port (RP), while the AGX Orin serves as the PCIe Endpoint (EP). The X86 PC achieves a write speed of 400 MB/s, but the read speed is only 40 MB/s. What could be the cause of this issue?
The Jetson AGX Orin is a high-performance module in the NVIDIA Jetson Orin Series, which also includes the Jetson Orin NX and Jetson Orin Nano Series. Here’s a comprehensive overview of the Jetson AGX Orin:
Architecture and Boot Flow
The Jetson AGX Orin follows the same software architecture as the other Jetson Orin Series modules, with a boot flow that includes the Bootloader, Kernel, and Root File System. The Boot Architecture section of the NVIDIA Jetson Linux Developer Guide provides more information on the boot flow for the Jetson AGX Orin, Orin NX, and Orin Nano.
Software Features
The Jetson AGX Orin supports various software features, including:
  1. Image Generation: The Jetson AGX Orin supports image generation tools like Flux & ComfyUI, Stable Diffusion, Stable Diffusion XL, and nerfstudio.
  2. RAG & Vector Database: The module supports RAG & Vector Database tools like NanoDB, LlamaIndex, and Jetson Copilot.
  3. SDK Integrations: The Jetson AGX Orin integrates with various SDKs, including Holoscan SDK, Jetson Platform Services, Gapi Workflows, Gapi Micro Services, and Ultralytics YOLOv8.
  4. Audio: The module supports audio tools like Whisper, AudioCraft, and VoiceCraft.
Benchmarks
The Jetson AGX Orin has been benchmarked for various tasks, and the results are available in the Benchmarks section of the NVIDIA Jetson Linux Developer Guide.
Hardware References
The Jetson AGX Orin Series has its own hardware references, including:
  1. Jetson Developer Kit Setup: The Jetson AGX Orin Series has a specific developer kit setup.
  2. Jetson EEPROM Layout: The module has a unique EEPROM layout.
  3. Jetson Module Adaptation and Bring-Up: The Jetson AGX Orin Series has its own module adaptation and bring-up process.
Comparison with Other Jetson Orin Series Modules
While the Jetson AGX Orin shares many similarities with the Jetson Orin NX and Jetson Orin Nano Series, there are some key differences:
  1. Performance: The Jetson AGX Orin is a high-performance module, while the Jetson Orin NX and Jetson Orin Nano Series are more power-efficient and compact.
  2. Software Support: The Jetson AGX Orin supports a wider range of software features and tools compared to the other Jetson Orin Series modules.
  3. Hardware Configuration: The Jetson AGX Orin has a unique hardware configuration, including a different EEPROM layout and module adaptation process.
In summary, the Jetson AGX Orin is a high-performance module in the NVIDIA Jetson Orin Series, with a wide range of software features and tools, and a unique hardware configuration.
May I ask if the slow reading speed is caused by incorrect configuration or is it due to limitations of the AGX hardware
Please check adaptation guide and see if you configure device tree correctly:
Jetson AGX Orin Platform Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide
Either C5 or C7 can achieve gen4 speed. If you use a custom Orin device, would suggest perform compliance test.
