I’m trying to run the lprnet.ipynb example and it fails on step 3. I am on Ubuntu 20.04. Has anyone managed to get this example working?
I have confirmed my Key, docker login, setup works because facenet.ipynb worked.
The command
print(“For multi-GPU, change --gpus based on your machine.”)
!tlt lprnet train --gpus=1 --gpu_index=0
-e $SPECS_DIR/tutorial_spec.txt
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
-m $USER_EXPERIMENT_DIR/pretrained_lprnet_baseline18/tlt_lprnet_vtrainable_v1.0/us_lprnet_baseline18_trainable.tlt
Returns the following error.
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 105, in run_experiment
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/model_io.py”, line 78, in load_model_as_pretrain
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/model_io.py”, line 41, in load_model
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/model_io.py”, line 29, in load_model
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/saving/save.py”, line 146, in load_model
loader_impl.parse_saved_model(filepath)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/saved_model/loader_impl.py”, line 83, in parse_saved_model
constants.SAVED_MODEL_FILENAME_PB))
OSError: SavedModel file does not exist at: /tmp/tmp18aaakmb.hdf5/{saved_model.pbtxt|saved_model.pb}
File “/usr/local/bin/lprnet”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/entrypoint/lprnet.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
2021-04-23 09:17:48,588 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
