I’ve a compilation problem with the following simple MACRO
more dummy.c
include <stdio.h>
include <stdlib.h>
define debug_clark(format, …) fprintf (stderr, format, ## VA_ARGS)
int main()
char var1[3]=“ab”;
int var2 = 5;
debug_clark(“%s %d\n”, var1, var2);
debug_clark(“ok\n”);
return 0;
The compilation with gcc and icc is ok, on the contrary the compilation with pgcc return the following error
pgcc -Minform=warn -c -o dummy.o dummy.c
PGC-S-0037-Syntax error: Recovery attempted by deleting ‘,’ (dummy.c: 13)
PGC/x86 Linux 7.1-6: compilation completed with severe errors
Can you give me a solution?
Many tanks
BC
