Hi I want to make GPIO20 to be set as LOW, where All I need to change if I am building the kernel/BSP from sources using tegra_defconfig? I know I need to change in pinmux config file to make it to drive 0. what else in which all files I need to make change?
HM_Tech
1
hello venkatraman.bhat,
here’s Jetson-IO python tool to simplify the configuration of the I/Os exposed by the 40‑pin expansion header.
please check developer guide for reference, Configuring the 40-Pin Expansion Header.
thanks
Related topics
| Xavier AGX power module abnormal | 6 | 166 | September 16, 2024 | |
| To configure GPIO pins in Jetson AGX XAVIER INDUSTRIAL | 99 | 3581 | December 4, 2023 | |
| NVIDIA / jetson-gpio | 6 | 1597 | September 29, 2021 | |
| AGX Xavier GPIO pins keep at zero | 3 | 838 | September 5, 2019 | |
| Jetson AGX Xavier Test 40 pin header on Jetpack4.5 | 25 | 3058 | October 21, 2021 | |
| GPIO customization on Jetson Platform | 5 | 14224 | December 28, 2023 | |
| Making a GPIO low in device tree of Xavier NX, Jetpack 4.5.1 | 10 | 743 | October 25, 2023 | |
| Crash jetson-io.py | 20 | 3671 | September 29, 2022 | |
| Keep `uart1_tx` low at boot | 4 | 734 | March 23, 2023 | |
| GPIO setting is not work | 13 | 3245 | June 23, 2021 |
