MCX516A-CCAT Both ports not working at the same time
I have a MCX516A-CCAT 100Gbe NIC with 2 ports. My goal is to utilize both ports with a 10G SFP+ transceiver adapter. However, I’m unable to get both ports sending/receiving data at the same time. Whichever port I plug in first is the one that works. For testing, I haave 2 separate computers connected to each port, trying to ping the respective IP address for each port. Pinging is successful on both ports when individually connected, but only one computer gets a ping response when both ports are plugged in.
Additional steps we have already tried:
  1. Attempted to override “slot power limit control” as mentioned in another post here: ConnectX-5 cable error/One or more network ports have been powered down due to insufficient/unadvertised power on the PCIe slot
  2. I am using firmware version 16.35.1012, verified by updating firmware as recommended in this post: MCX516A-CCAT : Unable to get both ports working
Log details from ibstat, mst status, ibv_devinfo, flint, and lspci:
$ mst status
MST modules:
    MST PCI module is not loaded
    MST PCI configuration module loaded
MST devices:
/dev/mst/mt4119_pciconf0         - PCI configuration cycles access.
                                   domain:bus:dev.fn=0000:06:00.0 addr.reg=88 data.reg=92 cr_bar.gw_offset=-1
                                   Chip revision is: 00
$ flint -d <device> q
Image type:            FS4
FW Version:            16.35.1012
FW Release Date:       28.10.2022
Product Version:       16.35.1012
Rom Info:              type=UEFI version=14.28.15 cpu=AMD64
                       type=PXE version=3.6.804 cpu=AMD64
Description:           UID                GuidsNumber
Base GUID:             58a2e10300395c74        8
Base MAC:              58a2e1395c74            8
Image VSD:             N/A
Device VSD:            N/A
PSID:                  MT_0000000012
Security Attributes:   N/A
$ ibstat
CA 'mlx5_0'
	CA type: MT4119
	Number of ports: 1
	Firmware version: 16.35.1012
	Hardware version: 0
	Node GUID: 0x58a2e10300395c74
	System image GUID: 0x58a2e10300395c74
	Port 1:
		State: Active
		Physical state: LinkUp
		Rate: 40
		Base lid: 0
		LMC: 0
		SM lid: 0
		Capability mask: 0x00010000
		Port GUID: 0x5aa2e1fffe395c74
		Link layer: Ethernet
CA 'mlx5_1'
	CA type: MT4119
	Number of ports: 1
	Hardware version: 0
	Node GUID: 0x58a2e10300395c75
	Port 1:
		State: Active
		Rate: 10
		Base lid: 0
		LMC: 0
		SM lid: 0
		Port GUID: 0x5aa2e1fffe395c75
$ ibv_devinfo
hca_id:	mlx5_0
	transport:			InfiniBand (0)
	fw_ver:				16.35.1012
	node_guid:			58a2:e103:0039:5c74
	sys_image_guid:			58a2:e103:0039:5c74
	vendor_id:			0x02c9
	vendor_part_id:			4119
	hw_ver:				0x0
	board_id:			MT_0000000012
	phys_port_cnt:			1
		port:	1
			state:			PORT_ACTIVE (4)
			max_mtu:		4096 (5)
			active_mtu:		1024 (3)
			sm_lid:			0
			port_lid:		0
			port_lmc:		0x00
			link_layer:		Ethernet
hca_id:	mlx5_1
	fw_ver:				16.35.1012
	node_guid:			58a2:e103:0039:5c75
	vendor_id:			0x02c9
	hw_ver:				0x0
	phys_port_cnt:			1
		port:	1
			max_mtu:		4096 (5)
			sm_lid:			0
			port_lid:		0
			port_lmc:		0x00
$ lspci -vv
06:00.0 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
	Subsystem: Mellanox Technologies Mellanox ConnectX-5 MCX516A-CCAT
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 16
	IOMMU group: 20
	Region 0: Memory at 6002000000 (64-bit, prefetchable) [size=32M]
	Expansion ROM at 85500000 [disabled] [size=1M]
	Capabilities: [60] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25W
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x16, ASPM not supported
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 8GT/s, Width x4 (downgraded)
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR-
			 10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS- TPHComp- ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
			 AtomicOpsCtl: ReqEn-
		LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
			 EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
			 Retimer- 2Retimers- CrosslinkRes: unsupported
	Capabilities: [48] Vital Product Data
		Product Name: CX516A - ConnectX-5 QSFP28
		Read-only fields:
			[PN] Part number: MCX516A-CCAT
			[EC] Engineering changes: B7
			[V2] Vendor specific: MCX516A-CCAT
			[SN] Serial number: MT23514004CY
			[V3] Vendor specific: 4a71112ca69dee11800058a2e1395c74
			[VA] Vendor specific: MLX:MODL=CX516A:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0
			[V0] Vendor specific: PCIeGen3 x16
			[VU] Vendor specific: MT23514004CYMLNXS0D0F0
			[RV] Reserved: checksum good, 2 byte(s) reserved
		End
	Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
		Vector table: BAR=0 offset=00002000
		PBA: BAR=0 offset=00003000
	Capabilities: [c0] Vendor Specific Information: Len=18 <?>
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [100 v1] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
		AERCap:	First Error Pointer: 08, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
	Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
		ARICap:	MFVC- ACS-, Next Function: 1
		ARICtl:	MFVC- ACS-, Function Group: 0
	Capabilities: [1c0 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn- PerformEqu-
		LaneErrStat: 0
	Capabilities: [230 v1] Access Control Services
		ACSCap:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
		ACSCtl:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
	Kernel driver in use: mlx5_core
	Kernel modules: mlx5_core
06:00.1 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
	Interrupt: pin B routed to IRQ 17
	IOMMU group: 21
	Region 0: Memory at 6000000000 (64-bit, prefetchable) [size=32M]
	Expansion ROM at 85400000 [disabled] [size=1M]
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
			 EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
		Read-only fields:
			[VU] Vendor specific: MT23514004CYMLNXS0D0F1
		End
		ARICap:	MFVC- ACS-, Next Function: 0
Any recommendations on getting both ports to work would be very helpful!
Thanks,
-Austin
Dear Customer,
Thank you for your inquiry on the NVIDIA Community.
I am having difficulty understanding some of your points, but I recommend the following steps to address your issue:
Upgrade Firmware and MLNX OFED
Please update both the firmware and MLNX OFED to the latest versions:
Firmware Downloads
MLNX OFED for Linux
Assign Different Subnets to Interfaces
Configure two different subnets for your interfaces. For example, assign 192.168.100.1/24 to one interface and 172.168.100.1/24 to the other.
If you have any further questions or concerns, please feel free to contact us:
Thank you,
Mellanox Technical Support
Thank you for the response. This issue has been resolved.
Assigning different subnets to each interface solved my problem, and allowed both ports to work simultaneously.
-Austin
