Hi all,
I have written a kernel that produces correct output on GTX 260 however when I open resource monitor I see physical memory usage shooting up hence eventually program crashes. So I am concerned about freeing up the memory. Does clMemReleaseObject() works correctly or there are some already known problems with it?
I am interfacing this OpenCL code with Matlab. And I have written an interface function (so called mex function) that makes the OpenCL context, initializes device variables and calls the kernel. In the end it frees up the variable using clReleaseMemObject(). Could someone please tell what if I am not freeing up the memory correctly? Also sometime sometime the code does not detect the GPU at all. It returns with the following error code:
“Error: Creating Context. (clCreateContextFromType) status is -2”
-2 is the number for CL_DEVICE_NOT_AVAILABLE
However if I keep on running it again and again it will pick up the device, hence i am kind of lost. So basically I have two problems:
Memory leak when I run the GPU code
clCreateContextFromType() fail intermittently with error code -2 (CL_DEVICE_NOT_AVAILABLE)
Could someone kindly check if my variable initialization is correct? The output of the kernel is a a variable LLR that I am reading back using clEnqueueReadBuffer(), is doing that correct? Is there a better way of initializing variables?? Am I not freeing up the memory correctly?? Any help would be highly appreciated.
System config:
SDK 4.0
Windows 7 64 bit
Geforce GTX 260
Matlab R2010a
Regards,
Richeek
#include <string.h>
#include"cl_resources.h"
#ifdef _CHAR16T
#define CHAR16_T
#endif
#include "mex.h"
#include <string.h>
#ifdef _CHAR16T
#define CHAR16_T
#endif
#include "mex.h"
void mexFunction (int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
cl_int status;
/* Initialize OpenCL resoruces */
status = initializeCL();
if(status != CL_SUCCESS)
return;
// input variables
float *R_re, *R_im, *dist_ZF,*s_re, *s_im , *symbol_alphabet_re, *symbol_alphabet_im;
bool *bittable;
int kk, nR, nT, nSym, *M, *symbols_ZF_i, total_bits,Sum_M,max_2_M;
size_t size;
cl_event events[2], ev;
// output variables
float *LLR;
if (nrhs!=7)
mexErrMsgTxt("7 input arguments required \n\n"
"[LLR] = soft_sd(R,s,dist_ZF,symbols_ZF,symbol_alphabet,bittable) ... soft Sphere Decoder\n\n"
" R ... upper triangular matrix obtained from the QR decomposition of the channel H (complex)\n"
" s ... received symbol vector, s=Q^H*y (nR x nSym) (complex)\n"
" dist_ZF ... Distance of the zero forcing solution (real)\n"
" symbols_ZF_i ... indices to symbols of the ZF solution (nT x nSym) (real integer)\n"
" M ... number of bits in the corresponding layer (1 x nR) (real)\n"
" symbol_alphabet ... for the demapping (2^M_max x nT) (complex)\n"
" bittable ... matrix containing the bits according to the symbol_alphabet (M x 2^M) (logical)\n"
" LLR ... max-log-MAP approximation of the LLR values (M*nR) (real)\n\n");
if (nlhs>1)
mexErrMsgTxt("One output lefthand argument required \n");
// check input variables
if ( ! mxIsComplex(prhs[0]) )
mexErrMsgTxt("1st argument 'R' must be a complex-valued (nR x nT) matrix");
if ( ! mxIsComplex(prhs[1]) )
mexErrMsgTxt("2nd argument 's' must be a complex-valued (nR x nSym) matrix");
if ( mxIsComplex(prhs[2]) )
mexErrMsgTxt("3rd argument 'dist_ZF' must be a real-valued (1 x nSym) matrix");
if ( mxIsComplex(prhs[3]) )
mexErrMsgTxt("4th argument 'symbols_ZF_i' must be a real-valued (nT x nSym) integer matrix");
if ( mxIsComplex(prhs[4]) )
mexErrMsgTxt("5th argument 'M' must be a real-valued (1 x nT) integer matrix");
if ( ! mxIsComplex(prhs[5]) )
mexErrMsgTxt("6th argument 'symbol_alphabet' must be a complex-valued (2^M_max x nT) matrix");
if ( ! mxIsLogical(prhs[6]) )
mexErrMsgTxt("7th argument 'bittable' must be a logical (M x 2^M) matrix");
nR = mxGetM(prhs[0]); // number of receive antennas
nT = mxGetN(prhs[0]); // number of transmit antennas
nSym = mxGetN(prhs[1]); // Block size (number of transmitted symbol vectors)
Sum_M = mxGetM(prhs[6]); // sum of the number of bits of M
max_2_M = mxGetN(prhs[6]); // Maximum value of 2^M
// fetch input variables
R_re = (float *)(mxGetPr(prhs[0])); // fetch pointer to real part of R
R_im = (float *)(mxGetPi(prhs[0])); // fetch pointer to imag part of R
s_re = (float *)(mxGetPr(prhs[1])); // fetch pointer to real part of s
s_im = (float *)(mxGetPi(prhs[1])); // fetch pointer to imag part of s
dist_ZF = (float *)(mxGetPr(prhs[2])); // fetch ZF distance
symbols_ZF_i = (int *)(mxGetPr(prhs[3])); // fetch pointer to imag part of ZF solution indices
M = (int *)(mxGetPr(prhs[4])); // fetch pointer to number of bits vector
symbol_alphabet_re = (float *)(mxGetPr(prhs[5])); // fetch pointer to real part of symbol alphabet
symbol_alphabet_im = (float *)(mxGetPi(prhs[5])); // fetch pointer to imag part of symbol alphabet
bittable = (bool *)(mxGetPr(prhs[6])); // fetch pointer to real part of bit mapping table
// allocate memory for output variables
total_bits = 0;
for(kk=0; kk<nT; kk++)
total_bits += M[kk];
size_t total_size = 0;
// Allocate Variables on the Device Global Memory of GPU and Load the input variables to the device
cl_mem R_re_d;
size = nR * nT * sizeof(float);
total_size += size;
R_re_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
mexPrintf("Error: Setting kernel argument. \n");
return ;
float* R_re_p;
R_re_p = (float *)clEnqueueMapBuffer(commandQueue,R_re_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
mexPrintf("Error: clEnqueueMapBuffer \n");
return;
memcpy(R_re_p, R_re, size);
/* Load the data back on the GPU */
status = clEnqueueUnmapMemObject(commandQueue,R_re_d,(void *)R_re_p,0,NULL,&ev);
mexPrintf("clEnqueueUnmapMemObject() failed\n");
return;
status = clWaitForEvents(1, &ev);
mexPrintf("clEnqueueUnmapMemObject() Release failed R_re_d\n");
return;
cl_mem s_re_d;
size = nT * nSym * sizeof(float);
total_size += size;
s_re_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
return;
float *s_re_p;
s_re_p = (float *)clEnqueueMapBuffer(commandQueue,s_re_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(s_re_p, s_re, size);
status = clEnqueueUnmapMemObject(commandQueue,s_re_d,(void*)s_re_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed s_re_d\n");
return;
cl_mem s_im_d;
total_size += size;
s_im_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
return;
float *s_im_p;
s_im_p = (float *)clEnqueueMapBuffer(commandQueue,s_im_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(s_im_p, s_im, size);
status = clEnqueueUnmapMemObject(commandQueue,s_im_d,(void *)s_im_p,0,NULL,&ev);
mexPrintf("clEnqueueUnmapMemObject() s_im failed\n");
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed s_im_d\n");
return;
cl_mem R_im_d;
total_size += size;
R_im_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
return ;
float *R_im_p;
R_im_p = (float *)clEnqueueMapBuffer(commandQueue,R_im_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(R_im_p, R_im, size);
status = clEnqueueUnmapMemObject(commandQueue,R_im_d,(void *)R_im_p,0,NULL,&ev);
mexPrintf("clEnqueueUnmapMemObject() failed R_im with status %d\n", status);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed R_im_d\n");
return;
cl_mem dist_ZF_d;
size = 1 * nSym * sizeof(float);
dist_ZF_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
total_size += size;
return;
float *dist_ZF_p;
dist_ZF_p = (float *)clEnqueueMapBuffer(commandQueue,dist_ZF_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(dist_ZF_p, dist_ZF, size);
status = clEnqueueUnmapMemObject(commandQueue,dist_ZF_d,(void *)dist_ZF_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed dist_ZF_d\n");
return;
cl_mem symbols_ZF_index_d;
size = nT * nSym * sizeof(int);
symbols_ZF_index_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
total_size += size;
return;
int *symbols_ZF_index_p;
symbols_ZF_index_p = (int*)clEnqueueMapBuffer(commandQueue,symbols_ZF_index_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(symbols_ZF_index_p, symbols_ZF_i, size);
status = clEnqueueUnmapMemObject(commandQueue,symbols_ZF_index_d,(void*)symbols_ZF_index_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed symbols_ZF_index_p\n");
return;
cl_mem M_d;
size = nT * 1 * sizeof(int);
M_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
total_size += size;
return;
int *M_p;
M_p = (int*)clEnqueueMapBuffer(commandQueue,M_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(M_p, M, size);
status = clEnqueueUnmapMemObject(commandQueue, M_d,(void *)M_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed M_d\n");
return;
cl_mem symbol_alphabet_re_d;
size = nT * max_2_M * sizeof(float);
total_size += size;
symbol_alphabet_re_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
return;
float *symbol_alphabet_re_p;
symbol_alphabet_re_p = (float *)clEnqueueMapBuffer(commandQueue,symbol_alphabet_re_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(symbol_alphabet_re_p, symbol_alphabet_re, size);
status = clEnqueueUnmapMemObject(commandQueue,symbol_alphabet_re_d,(void *)symbol_alphabet_re_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed symbol_alphabet_re_d\n");
return;
cl_mem symbol_alphabet_im_d;
symbol_alphabet_im_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
total_size += size;
return;
float *symbol_alphabet_im_p;
symbol_alphabet_im_p = (float *)clEnqueueMapBuffer(commandQueue,symbol_alphabet_im_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(symbol_alphabet_im_p, symbol_alphabet_im, size);
status = clEnqueueUnmapMemObject(commandQueue,symbol_alphabet_im_d,(void *)symbol_alphabet_im_p,0,NULL,&ev);
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed symbol_alphabet_im_d\n");
return;
cl_mem bittable_d;
size = Sum_M * max_2_M * sizeof(bool);
bittable_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
total_size += size;
// return;
bool *bittable_p;
bittable_p = (bool*)clEnqueueMapBuffer(commandQueue,bittable_d,CL_TRUE,CL_MAP_WRITE,0,size,0,NULL,NULL,&status);
return;
memcpy(bittable_p, bittable, size);
status = clEnqueueUnmapMemObject(commandQueue,bittable_d,(void*)bittable_p,0,NULL,&ev);
mexPrintf("clEnqueueUnmapMemObject() failed bittable\n");
return;
mexPrintf("clEnqueueUnmapMemObject() Release failed bittable_d\n");
return;
/* This is the output */
cl_mem LLR_d;
size = Sum_M *nSym * sizeof(float);
total_size += size;
LLR_d = clCreateBuffer(context, CL_MEM_READ_WRITE, size, NULL, &status);
return;
//mexPrintf("Total allocated memory is %d\n", total_size);
/* Set kernel Arguments */
/*** Set appropriate arguments to the kernel ***/
status = clSetKernelArg(kernel, 0, sizeof(cl_mem), (void *)&R_re_d);
mexPrintf("Error: Setting kernel argument.\n");
return;
status = clSetKernelArg(kernel, 1, sizeof(cl_mem), (void *)&R_im_d);
mexPrintf("Error: Setting kernel argument\n");
return;
status = clSetKernelArg(kernel, 2, sizeof(cl_mem), (void *)&s_re_d);
return;
status = clSetKernelArg(kernel, 3, sizeof(cl_mem), (void *)&s_im_d);
return;
status = clSetKernelArg(kernel, 4, sizeof(cl_mem), (void *)&dist_ZF_d);
return;
status = clSetKernelArg(kernel, 5, sizeof(cl_mem), (void *)&symbols_ZF_index_d);
return;
status = clSetKernelArg(kernel, 6, sizeof(cl_mem), (void *)&symbol_alphabet_re_d);
return;
status = clSetKernelArg(kernel, 7, sizeof(cl_mem), (void *)&symbol_alphabet_im_d);
return;
status = clSetKernelArg(kernel, 8, sizeof(cl_mem), (void *)&bittable_d);
return;
status = clSetKernelArg(kernel, 9, sizeof(cl_mem), (void *)&LLR_d);
return;
status = clSetKernelArg(kernel, 10, sizeof(int), (void *)&nSym);
return;
status = clSetKernelArg(kernel, 11, sizeof(cl_mem), (void *)&M_d);
return;
status = clSetKernelArg(kernel, 12, sizeof(int), (void *)&nT);
return;
status = clSetKernelArg(kernel, 13, sizeof(int), (void *)&nR);
return;
status = clSetKernelArg(kernel, 14, sizeof(int), (void *)&total_bits);
return;
size_t localThreads[2] = {128, 1};
size_t globalThreads[2] = {nSym, 1};
status = clEnqueueNDRangeKernel(commandQueue, kernel, 2, NULL, globalThreads, localThreads, 0, NULL, &events[0]);
mexPrintf("Error: Enqueueing kernel onto command queue. (clEnqueueNDRangeKernel)\n");
return;
/* wait for the kernel call to finish execution */
status = clWaitForEvents(1, &events[0]);
mexPrintf("Error: Waiting for kernel run to finish.(clWaitForEvents)\n");
return;
// output variable with Sphere Decoder solution of single precision type
plhs [0] = mxCreateNumericMatrix(total_bits,nSym,mxSINGLE_CLASS,mxREAL);
if(plhs[0] == NULL)
mexErrMsgTxt("mxCreateNumericMatrix failed(1)\n");
LLR = (float *) mxGetPr(plhs[0]); // fetch pointer for output variable
if(LLR == NULL )
mexErrMsgTxt("mxCreateNumericMatrix failed(2)\n");
//Copy the data back from the GPU
status = clEnqueueReadBuffer(commandQueue,LLR_d,CL_TRUE,0,size,LLR,0,0,&ev);
mexPrintf("Error in reading LLR buffer Status is: %d size is(bytes) %d\n", status, size);
mexPrintf("Error: Waiting for LLR read to finish.(clWaitForEvents) status is \n", status);
return;
//free up the host memory
//free(R_re_p);
//R_re_p = NULL;
//free(R_im_p);
//R_im_p = NULL;
//free(s_re_p);
//s_re_p = NULL;
//free(s_im_p);
//s_im_p = NULL;
//free(symbols_ZF_index_p);
//symbols_ZF_index_p = NULL;
//free(M_p);
//M_p = NULL;
//free(symbol_alphabet_re_p);
//symbol_alphabet_re_p = NULL;
//free(symbol_alphabet_im_p);
//symbol_alphabet_im_p = NULL;
//free(bittable_p);
//bittable_p = NULL;
// Free device memory
status = 0;
status = clReleaseKernel(kernel);
status += clReleaseProgram(program);
status += clReleaseMemObject(R_re_d);
status += clReleaseMemObject(R_im_d);
status += clReleaseMemObject(s_re_d);
status += clReleaseMemObject(s_im_d);
status += clReleaseMemObject(dist_ZF_d);
status += clReleaseMemObject(symbols_ZF_index_d);
status += clReleaseMemObject(M_d);
status += clReleaseMemObject(symbol_alphabet_re_d);
status += clReleaseMemObject(symbol_alphabet_im_d);
status += clReleaseMemObject(bittable_d);
status += clReleaseMemObject(LLR_d);
status += clReleaseCommandQueue(commandQueue);
status += clReleaseContext(context);
if(status != 0)
mexPrintf("Error in freeing up the memory");
And this is the OpenCL initialization code:
#include "cl_resources.h"
#ifdef _CHAR16T
#define CHAR16_T
#endif
#include "mex.h"
cl_context context;
cl_device_id *devices;
cl_command_queue commandQueue;
cl_program program;
cl_kernel kernel;
* Converts the contents of a file into a string
int convertToString(const char *filename, std::string& s)
size_t size;
char* str;
std::fstream f(filename, (std::fstream::in | std::fstream::binary));
if(f.is_open())
size_t fileSize;
f.seekg(0, std::fstream::end);
size = fileSize = (size_t)f.tellg();
f.seekg(0, std::fstream::beg);
str = new char;
if(!str)
f.close();
return NULL;
f.read(str, fileSize);
f.close();
str = '
#include “cl_resources.h”
#ifdef _CHAR16T
#define CHAR16_T
#include “mex.h”
cl_context context;
cl_program program;
cl_kernel kernel;
- Converts the contents of a file into a string
size_t size;
char* str;
if(f.is_open())
size_t fileSize;
str = new char;
if(!str)
f.close();
return NULL;
f.close();
str = '\0';
s = str;
delete[] str;
return 0;
mexPrintf("Error: Failed to open file %s\n", filename);
return 1;
\brief OpenCL related initialization
Create Context, Device list, Command Queue -
Create OpenCL memory buffer objects -
Load CL file, compile, link CL source -
Build program and kernel objects
int initializeCL(void)
cl_int status = 0;
size_t deviceListSize;
cl_uint numPlatforms;
cl_platform_id platform = NULL;
status = clGetPlatformIDs(0, NULL, &numPlatforms);
mexPrintf("Error: Getting Platforms. (clGetPlatformsIDs)\n");
return 1;
if(numPlatforms > 0)
cl_platform_id* platforms = (cl_platform_id *)malloc(numPlatforms*sizeof(cl_platform_id));
status = clGetPlatformIDs(numPlatforms, platforms, NULL);
mexPrintf("Error: Getting Platform Ids. (clGetPlatformsIDs)\n");
return 1;
for(unsigned int i=0; i < numPlatforms; ++i)
char pbuff[100];
status = clGetPlatformInfo(
platforms[i],
CL_PLATFORM_VENDOR,
sizeof(pbuff),
pbuff,
NULL);
mexPrintf("Error: Getting Platform Info. (clGetPlatformInfo)\n");
return 1;
platform = platforms[i];
if(!strcmp(pbuff, "Advanced Micro Devices, Inc."))
break;
delete platforms;
if(NULL == platform)
std::cout << "NULL platform found so Exiting Application." << std::endl;
return 1;
cl_context_properties cps[3] = { CL_CONTEXT_PLATFORM, (cl_context_properties)platform, 0 };
// Create an OpenCL context
context = clCreateContextFromType(cps, CL_DEVICE_TYPE_GPU, NULL, NULL, &status);
mexPrintf("Error: Creating Context. (clCreateContextFromType) status is %d\n", status);
return 1;
/* First, get the size of device list data */
status = clGetContextInfo(context,
CL_CONTEXT_DEVICES,
0,
NULL,
&deviceListSize);
mexPrintf(
"Error: Getting Context Info \
(device list size, clGetContextInfo)\n");
return 1;
// Detect OpenCL devices
devices = (cl_device_id *)malloc(deviceListSize);
if(devices == 0)
mexPrintf("Error: No devices found.\n");
return 1;
/* Now, get the device list data */
context,
CL_CONTEXT_DEVICES,
deviceListSize,
devices,
NULL);
mexPrintf("Error: Getting Context Info \
(device list, clGetContextInfo)\n");
return 1;
// Create an OpenCL command queue
commandQueue = clCreateCommandQueue(
context,
devices[0],
0,
&status);
mexPrintf("Creating Command Queue. (clCreateCommandQueue)\n");
return 1;
// Load CL file, build CL program object, create CL kernel object
const char * filename = "sts_kernel.cl";
std::string sourceStr;
status = convertToString(filename, sourceStr);
return 1;
const char * source = sourceStr.c_str();
size_t sourceSize[] = { strlen(source) };
program = clCreateProgramWithSource(
context,
1,
&source,
sourceSize,
&status);
mexPrintf("Error: Loading Binary into cl_program \
(clCreateProgramWithBinary)\n");
return 1;
/* create a cl program executable for all the devices specified */
char* build_log;
size_t log_size;
status = clBuildProgram(program, 1, devices, NULL, NULL, NULL);
mexPrintf("Error: Building Program (clBuildProgram)\n");
// First call to know the proper size
clGetProgramBuildInfo(program, devices[0], CL_PROGRAM_BUILD_LOG, 0, NULL, &log_size);
build_log = new char[log_size+1];
// Second call to get the log
clGetProgramBuildInfo(program, devices[0], CL_PROGRAM_BUILD_LOG, log_size, build_log, NULL);
build_log[log_size] = '\0';
mexPrintf("%s\n", build_log);
delete[] build_log;
return 1;
/* get a kernel object handle for a kernel with the given name */
kernel = clCreateKernel(program, "sts_kernel", &status);
mexPrintf("Error: Creating Kernel from program. (clCreateKernel)\n");
return 1;
return 0;
s = str;
delete[] str;
return 0;
return 1;
* \brief OpenCL related initialization
* Create Context, Device list, Command Queue
* Create OpenCL memory buffer objects
* Load CL file, compile, link CL source
* Build program and kernel objects
cl_int status = 0;
return 1;
return 1;
char pbuff[100];
platforms[i],
CL_PLATFORM_VENDOR,
sizeof(pbuff),
pbuff,
NULL);
return 1;
break;
delete platforms;
return 1;
return 1;
CL_CONTEXT_DEVICES,
0,
NULL,
&deviceListSize);
mexPrintf(
return 1;
if(devices == 0)
return 1;
context,
CL_CONTEXT_DEVICES,
deviceListSize,
devices,
NULL);
return 1;
context,
devices[0],
0,
&status);
return 1;
return 1;
context,
1,
&source,
sourceSize,
&status);
return 1;
char* build_log;
size_t log_size;
#ifdef _CHAR16T
#define CHAR16_T
#include “mex.h”
cl_context context;
cl_program program;
cl_kernel kernel;
size_t size;
char* str;
if(f.is_open())
size_t fileSize;
str = new char;
if(!str)
f.close();
return NULL;
f.close();
str = '\0';
s = str;
delete[] str;
return 0;
return 1;
cl_int status = 0;
return 1;
return 1;
char pbuff[100];
platforms[i],
CL_PLATFORM_VENDOR,
sizeof(pbuff),
pbuff,
NULL);
return 1;
break;
delete platforms;
return 1;
return 1;
CL_CONTEXT_DEVICES,
0,
NULL,
&deviceListSize);
mexPrintf(
return 1;
if(devices == 0)
return 1;
context,
CL_CONTEXT_DEVICES,
deviceListSize,
devices,
NULL);
return 1;
context,
devices[0],
0,
&status);
return 1;
return 1;
context,
1,
&source,
sourceSize,
&status);
return 1;
char* build_log;
size_t log_size;
delete[] build_log;
return 1;
return 1;
return 0;
delete[] build_log;
return 1;
return 1;
return 0;
Both these codes are fairly simple all they are doing is setting up the environment to run the kernel. Again thanks for the help.
