: Jetson Nano
• DeepStream Version
: DS 4.0.1
: Jetpack 4.2.2
Hello.
I am trying to receive mjpeg rtsp stream from camera using Deepstream.
By the way, after the project runs, the gpu memory keeps increasing.
Then the jetson board is forcibly terminated.
I checked other forums with the same problem, and I saw a post saying that replacing nvjpecdec with nvv4l2decoder will solve it.
Or, in deepstream_source_bin.c, I saw an article saying that you can set the mjpeg property to 1 in the cb_rtspsrc_select_stream function, but I could not solve it.
How can I use MJPEG RTSP stream in Deepstream 4.0.1 SDK without memory leak?
How can I change Decoder nvjpegdec to nvv4l2decoder?
Need to change the source code?
