Jetson
• DeepStream Version
deepstream6.2 & deepstream6.3 both
5.1.1
• TensorRT Version
8.5.2.2
bugs
When I was using deepstream’s instance segmentation feature with the yolov5-seg model and passing the mask to the corresponding data NvDsInferInstanceMaskInfo through post-processing, I noticed a slight memory leak. The phenomenon is that when there are many input paths and targets, the occupied memory slowly increases. This phenomenon occurs in both version 6.2 and 6.3. I’m not sure if it’s a bug or a problem with my program. After a simple trace of the issue, it seems that the memory leak occurs before the release of mask in the InstanceSegmentPostprocessor::fillDetectionOutput function, specifically in the fillUnclusteredOutput(output) function. If I release the mask before this function, the memory growth stops but the target boxes are no longer drawn. I hope to get a response as soon as possible, thank you.
