MGBE Lines
We have connected the Orin Module MGBE Lines to Orin Module MGBE Lines, as mentioned below. Please verify and confirm , whether it works or not?.
Hi Sridhar,
Please mention which Orin module are they.
NVidia Jetson AGX Orin (64 GB)
Hi, it is not validated. Only below design is supported as you can see in DG.
OK thank you for your reply.
Can you please tell us what is the max speed does the signal UPHY_TX/RX pair supports.
It’s up to 16Gbps @ gen4.
