Hello!
I am using a custom version of the carrier board and a jetson nano module with EMMC memory. There is a micro SD card slot on the carrier board. With constant power on, there are no problems with the memory card working.
sdhci@700b0400 {
status = "okay";
cd-gpios = <&gpio TEGRA_GPIO(V, 0) 0>;
nvidia,vmmc-always-on;
/delete-property/ keep-power-in-suspend;
vmmc-supply = <&p3448_vdd_3v3_sd>;
non-removable;
cd-inverted;
wp-inverted;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-hs200-1_8v;
no-sdio;
no-mmc;
When I remove non-removable and nvidia,vmmc-always-on, the power to the card starts to be out of phase. When there is no card, there is power; when there is a card, there is no power. The Cd-inverted option has no effect, I tried both with and without it.
sdhci@700b0400 {
status = "okay";
/delete-property/ nvidia,vmmc-always-on;
/delete-property/ non-removable;
cd-inverted;
wp-inverted;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-hs200-1_8v;
no-sdio;
no-mmc;
What could be the problem? DTS second option attached.
current.dts (318.9 KB)
