Firstly, I know that there are several very similar topics in the forum, and it’s very possible that this topic is redundant, if so - apologies.
That being said, it seemed to me that none of the existing MicroSD topics exactly suited my situation, and I didn’t find a solution which solved my problem.
I am using the AAEON-8250AI Jetson Xavier Nx , which came flashed from the provider.
System info:
aaeon@aaeon-desktop:~$ uname -a
Linux aaeon-desktop 4.9.140-tegra #1 SMP PREEMPT Tue Oct 27 21:02:46 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
aaeon@aaeon-desktop:~$ dmesg -T
[Sun Jan 17 18:49:38 2021] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4294) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Oct 27 21:02:46 PDT 2020
aaeon@aaeon-desktop:~$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t186ref, EABI: aarch64, DATE: Fri Oct 16 19:37:08 UTC 2020
The jtop application says Jetpack version is: 4.4.1 [L4T 32.4.4]
As of last Tursday, I was using a 64GB Micro SD card in the Jetson, which was being auto-mounted via /etc/fstab.
This is the fstab entry that was successfully mounting the SD card:
UUID=2ef05944-2e9d-4053-bd7f-4bde7c326886 /mnt/NxSD64GB/ ext4 errors=remount-ro,auto,rw,user,exec 0 0
Last Thursday I rebooted the device, and all of a sudden the MicroSD device disappeared (and, obviously, the auto-mount fails - I had to remove the line from fstab).
lsblk, fdisk -l, df -h - none of these commands show the MicroSD device.
Following a suggestion in another topic I ran the command:
dtc -I fs -O dts -o /tmp/extracted.dts /proc/device-tree
Here is the output:
extracted.dts (246.5 KB)
Indeed sdmmc3 has status = "disabled", but I’m unclear how I can change that.
There is no flash.sh script on my Jetson.
There doesn’t seem to be any Linux_for_Tegra directory anywhere on my Jetson.
Side note:
There is an additional problem, which has started at the same time, but I don’t know if it’s related.
Since the same reboot which disappeared the MicroSD device, I am unable to start a GUI session (see image below). I am only able to connect via a virtual console (i.e: ctrl + alt + f2)
Thanks,
Tuval
