Jetson Xavier NX, Micro SD not detected
My Jetson Xavier NX will not detect the Micro SD card. I have tried both an exFAT and NTFS file systems on the Micro SD card and neither have worked. Below are the dmesg console logs:
I currently have JetPack 5.0 installed on my Jetson Xavier NX.
$ dmesg|tail
[  774.628138] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  779.747964] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  784.867971] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  789.988001] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  795.107905] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  800.227963] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  805.347858] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  810.467865] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  815.587849] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[  820.707999] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1   14G  8.3G  4.8G  64% /
none            3.4G     0  3.4G   0% /dev
tmpfs           3.4G   36K  3.4G   1% /dev/shm
tmpfs           686M   19M  667M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           3.4G     0  3.4G   0% /sys/fs/cgroup
tmpfs           686M   20K  686M   1% /run/user/124
tmpfs           686M   20K  686M   1% /run/user/1000
Is that sdcard is on the carrier board?
Yes, it is directly mounted to the carrier board.
Is that carrier board made by yourself or it is provided by a vendor?
By default, none of our software supports extra sdcard slot. Generally, the vendor board requires extra configuration in device tree to make it work.
It is a Simatic Box PC (IPC520A), with a built in Nvidia Jetson Xavier NX.
Then you need to contact the board vendor for their customized BSP.
Sdkmanager/jetpack do not support such kind of board. If you have any question regarding why we cannot provide, please let me know.
