I’m very new to cuda.
I installed the cuda sdk, the drivers for vista and I’m using GeForce 7900 GS
I’m also using visual c++ 2005 on vista.
I just tried to run the sample programs coming with the cuda sdk.
The build was ok but when I started the debug (emuDebug, debug, release) I got an exception from VC++ as following:
First-chance exception at 0x7c812afb in matrixMul.exe: Microsoft C++ exception: cudaError at memory location 0x0012fe20…
Microsoft C++ exception: cudaError at memory location 0x0012fc24…
Microsoft C++ exception: cudaError at memory location 0x0012fc80…
I tried to investigate for the solution but could not solve it.
Your help will be welcome.
Thank you.
