Migrating Phy 88E1512 with Orin board
Our custom carrier board will use the PHY 88E1512 with JetPack 6.2.
Since this is not the default PHY, we need to perform a customization process.
I have read various posts and the official documentation:
Jetson Module Adaptation and Bring-Up Guide.
However, I am now more confused about which files need to be modified and how to proceed.
Is there a step-by-step guide available to help with this process?
You could look into /boot/dtb on your Jetson to know where to start first.
I never really “memorize” which dtb should modify. If you know where to start and where to download source code, then it is basically code tracing.
But should this migration work? Or there are issues with it?
88E1512 is actually a very common phy in use by other users. So shall not have problem.
