Migrating pipeline from orin/deepstream 7.1 to dgx/deepstream 8.0
dgx spark - NVIDIA GB10
• DeepStream Version
deepstream 8.0
• TensorRT Version
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
new requirements
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
created a docker container** FROM nvcr.io/nvidia/deepstream:8.0-triton-dgx-spark
this pipeline, that worked in orin/ds7.1
! nvinfer [ … ]
! nvtracker [ … ]
! queue max-size-buffers=0 leaky=2
! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080
! nvvideoconvert name=raw_tiler_probe
! video/x-raw(memory:NVMM),format=NV12
! nvjpegenc quality=80
! fakesink async=true name=jpeg_tiler_probe
was modified to
! nvinfer [ … ]
! nvtracker [ … ]
! video/x-raw,format=I420
to make it work, but now the jpeg_tiler_probe probe gives this error
l_frame = batch_meta.frame_meta_list
AttributeError: ‘NoneType’ object has no attribute ‘frame_meta_list’
gpt suggests to split the pipeline like this
… ! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080
! tee name=t
t. ! queue max-size-buffers=0 leaky=2
! fakesink async=true name=meta_sink
! nvvideoconvert
! appsink name=jpeg_sink emit-signals=true sync=false max-buffers=1 drop=true
is there a retrocompatible way to do this and avoid two probes? (one for the frame and one for the detections)
thank you, William
This problem seems to be caused by an incorrect Python binding installation? Could you share the command line for starting the container, and how to install pyds?
We generally recommend adding different probes on different pads because batchmeta/framemeta/objectmeta, etc., are modified in the pipeline, and adding only one probe might cause you to miss some information.
hi @junshengy
the python bindings are the latest version for deepstream 8.0, so 1.2.2
this is the dockerfile i used
ENV DEBIAN_FRONTEND=noninteractive
ENV DS_VERSION=8.0.0
RUN /opt/nvidia/deepstream/deepstream/user_additional_install.sh
RUN /opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh --version 1.2.2
RUN pip3 install /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/pyds-1.2.2-cp312-cp312-linux_aarch64.whl
the container was started with this command
docker run --runtime nvidia -v ./:/app -it nvcr.io/nvidia/deepstream:8.0-triton-dgx-spark bash
i only need one probe for the tiler + detections, at the end of the pipeline, so i don’t think i need other probes
if you compare the 2 pipelines you notice that
was changed to
because i inspected nvjpegenc in deepstream 8.0 for dgx spark and
Pad Templates:
SINK template: ‘sink’
Availability: Always
Capabilities:
  video/x-raw(memory:CUDAMemory)
             format: { (string)I420, (string)Y42B, (string)Y444 }
              width: \[ 1, 2147483647 \]
             height: \[ 1, 2147483647 \]
  video/x-raw
the input memory changed from NVMM to CUDAMemory (so i removed memory:NVMM from the pipeline) and the format changed to I420 (instead of the NV12 in the orin ds 7.1)
could be this the reason for the python bindings to not find the batch_meta.frame_meta_list?
thank you for your help, William
*cp312-linux_aarch64.whl is a pre-compiled binary for Jetson, which is incompatible with Spark(which is a SBSA device). It’s best to compile the whl file from source code, like this.
ENV CMAKE_ARGS="-DIS_SBSA=on"
RUN /opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh -b --version 1.2.2
Then create a container on the command line like this. These parameters affect nvidia-container-toolkit
docker run -it --rm --runtime=nvidia --network=host -e
NVIDIA_DRIVER_CAPABILITIES=compute,utility,video,graphics --gpus all
--privileged -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v
/etc/X11:/etc/X11 nvcr.io/nvidia/deepstream:8.0-triton-arm-sbsa
This link explained these parameters.
There are two plugins called nvjpegenc, provided by the NVIDIA and GStreamer communities, and it appears they conflict with each other on the Spark platform.
Try to use nvimageenc with a DeepStream pipeline to avoid this conflict.
thank you, it worked with nvimageenc instead of nvjpegenc!
