When the same camera module is connected to the Orin Nano, the LP voltage level in the MIPI signal (normally 1.2V) is pulled down to 0.8V-0.9V, resulting in the inability to capture video.
However, when connected to the Orin AGX, the amplitude is normal, and image capture works properly.
Please note that the MIPI signal of the module is sourced from the FPGA, and the circuit output structure is as follows:
PS: I am using JetPack 5.1.1. This camera can be successfully connected to other Jetson boards except for Orin Nano and Orin NX (Orin NX also uses P3509 as the carrier board). And I believe the dts is correct.
Hi, how did you connect camera to camera connector of Orin NX/Nano? The camera connector of Orin is different to Orin NX/Nano. The Orin NX/Nano devkit has been validated no problem on the camera input. If possible, please use a regular sensor module instead of a FPGA source to have a try.
I’m sorry, I have identified the cause of the problem. Because this board requires a 15-to-22pin FFC cable, the FFC cable I used was too thin, resulting in a large voltage drop. Please close this post.
