Hello there;
I have an OV9284 sensor. It is very similar to OV9281, in fact when I read the ID registers I get 9281. This sensor is on a custom board which is then connected to the AGX XAVIER camera input. I know the I2C works because when I run i2cdetect command I can see my I2C and I have used a Python script (smbus library) to write and read the camera’s registers. I can see that my camera is streaming and sending MIPI signals over but on the XAVIER I can not detect the camera. When I run any v4l2 command or any gstreamer command, it says no camera was found. When I do ls /dev/video*, again it tells me No such file or directory. I am fairly new to all of this so I am not sure where to go from here.
Any help is appreciated.
