I connected jetson agx and LI-IMX274-MIPI-M12 camera. But the computer does not see the camera. When I connect usb camera, it sees it.
bash: cd: /dev/video0: No such file or directory
First, you should never cd
to the /dev/video0
node, because that’s a (character special) file, not a directory. If you want to see whether it’s there, you need to use something like ls -l /dev/video0
Second, did you install the kernel module / driver for the camera, and set the Jetson to expect that camera? I assume from the model number that it has a supported sensor, but does it also have a supported I2C control board? (E g, is this particular model on the list of verified-compatible cameras?)
Thank you for your answer
1- I tried as you said, it still didn’t work.
2- I’m new to these topics, can you tell me how to do it?
Please consult with Leopard to get the driver for your sensor board.
@SimonZhu
Could you provide the driver.
@passenger
Please check your BSP version by cat /etc/nv_tegra_rlease
cat: /etc/nv_tegra_rlease: No such file or directory
Sorry to typo
cat /etc/nv_tegra_release
@passenger Our latest Xavier IMX274 driver is based on R32.5.0. Please download the driver guide below.
@passenger Please follow the instruction in page 3 to install the driver. You may need to download the R32.5.0 OS image from our driver guide and flash it to Xavier (step1) before installing the driver.
@passenger If you are using R32.5.1 OS, the R32.5.0 driver may not work, so it’s better to re-flash the Xavier with R32.5.0 OS image and then install the driver.
@SimonZhu
OK. I understand. but i want to try. Will my files be deleted only when I install the driver? I want to learn this.
I tired you. thank you.
good day
