mlx5_core enable hca failed, mlx5_load_one failed with error code -22
I have two physical cards each with two ports but only one Physical card is getting enabled and getting following error on the dmesg
for i in $(lspci | grep Mellanox | awk ‘{print $1}’); do echo $i; lspci -vv -s $i | grep “Part number” -A 3; done
03:00.0
[PN] Part number: MCX456A-ECAT
[EC] Engineering changes: A4
[SN] Serial number: MT1514X00006
[V0] Vendor specific: PCIeGen3 x16
03:00.1
90:00.0
[EC] Engineering changes: A8
[SN] Serial number: MT1621K00548
90:00.1
$ lspci | grep Mellanox
03:00.0 Infiniband controller: Mellanox Technologies MT27700 Family [ConnectX-4]
03:00.1 Infiniband controller: Mellanox Technologies MT27700 Family [ConnectX-4]
90:00.0 Infiniband controller: Mellanox Technologies MT27700 Family [ConnectX-4]
90:00.1 Infiniband controller: Mellanox Technologies MT27700 Family [ConnectX-4]
[pasokan@sn18 ~]$
$ ibstat
CA ‘mlx5_0’
CA type: MT4115
Number of ports: 1
Firmware version: 12.22.1002
Hardware version: 0
Node GUID: 0x248a0703001cdfd4
System image GUID: 0x248a0703001cdfd4
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 128
LMC: 0
SM lid: 1
Capability mask: 0x2651e848
Port GUID: 0x248a0703001cdfd4
Link layer: InfiniBand
CA ‘mlx5_1’
CA type: MT4115
Number of ports: 1
Hardware version: 0
Node GUID: 0x248a0703001cdfd5
Port 1:
State: Active
Rate: 56
Base lid: 129
LMC: 0
SM lid: 1
Port GUID: 0x248a0703001cdfd5
Hi Pharthiphan,
I am not sure if your issue is still relevant as it was posted on 6/11, however what Mellanox OFED Drivers did you installed and have you validated the FW version/compatibility?
You can download the MFT package from the following link:
Mellanox Firmware Tools (MFT) Mellanox Firmware Tools (MFT)
To query the FW:
#mst start
#mst status -v
#flint -d q
Note: Check based on the RN of the Drivers that the FW is supported/compatible. If not, I would suggest to align the FW to a supported version.
Sophie.
